Local Time 06:45 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SDR recommendations?
BrianP
Posted: 08:48am 02 Jun 2018
Hi all
I'm thinking about acquiring a USB SDR to use for spectrum analysis, ideally up to 3ghz or so, or 5ghz if affordable.
Does anyone have a pet recommendation, ideally with a supplier?
Thanks in advance for your time...
Brian P
Chopperp
Posted: 11:19am 02 Jun 2018
Silicon Chip had this feature May'13. May help
LINK
ChopperP
Phil23
Posted: 09:21pm 02 Jun 2018
They also did an updated article in Nov 2017, based on a kit from Banggood.
Being based on TV dongles, they are not going to make it to 2Gig.
Here's the kit anyway.
Cheers.
Phil23
Posted: 09:25pm 02 Jun 2018
A down converter would get the range higher.
Bit of info here.
BrianP
Posted: 01:56am 03 Jun 2018
Thanks guys
I have ordered an RTL-SDR R820T2 (RTL2832U v3) SDR with Dipole Antenna Kit from a local supplier for $45 including delivery - I didn't think that was a bad deal from a local company. I'll work on a down converter later after I've been through the learning curve with the base unit.
The journey begins...
Thanks again
B
cs41
Posted: 06:53am 04 Jun 2018
I too have been researching SDR modules for receiving meteorological weather satellite transmissions around 1700 MHz and so far the best I have tried which is reasonably priced is the Nooelec Extended range model
http://www.nooelec.com/store/sdr/nesdr-smart-xtr-sdr.html
I have one and quite satisfied with the results so far up to about 2200MHz.
Some of the other ones I have tried are rather unreliable above about 1600 MHz, especially when warm.
cs
