Local Time 06:47 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : vartble structure
Quazee137
Posted: 07:32pm 04 Jun 2018
What is the structure of the vartbl ?
I have been trying code snippets from TBS in 2014 on using FRAM.
I can write/read/clear the chip with that code.
The next part is using the VARTBL and this is as far as I have got.
showvar.bas
'The showvar code is gleamed from TassyJim short array code. Thanks again for helping me to some what understand things.
'I am still trying to figure out the rest of the table
'the init code is ripped from my quad tower controller test.
'What I am trying to do is copy the var functionality to FRAM's.
'my test chip is 8k by 8 and on the DS3231 RTC module and that is 4 times the flash space of the 170
'later I will try the larger FRAM 128K by 8. Thats a lota storage for the 28 pin Mite. Still reading pdf
'OPTION COLOURCODE ON
'OPTION DISPLAY 24,132 easier to see it all
Option base 1
Option EXPLICIT
Dim test(2,2,2,2,2,2,2) length 2
'data arrays
Dim fn=100,r$(fn) length 1, f$(fn) length 1, d$(fn) length 4, s$(fn) length 4
Dim day$(fn) length 2
'runtime display vars
Dim rn$(4) length 9,dd$(4) length 4, ds$(4) length 4, df$(4) length 1
Dim c,count(4),fsc
'touch
Dim tx,ty,itx,ity,itx2,ity2,icx,icy,row,srow,col,penup=1,pendown=0
' mis keyboard vars "testing wip they cant decide which one to use"
Dim key$(45)=("1","2","3","4","5","6","7","8","9","0",".","q","w","e","r","t","y","u","i","o","p","*","a","s","d","f","g","h ","j","k","l",":","/","z","x","c","v","b","n","m","#","-","^","^"," ") length 1
Dim ar$(36)=("00","01","02","03","04","05","06","07","08","09","10","11","12","13","14","15","16","17","18","19","20","21"," 22","23","00","05","10","15","20","25","30","35","40","45","50","55")
Dim week$(35)=("Sun","Mon","Tue","Wed","Thr","Fri","Sat"," 1"," 2"," 3"," 4"," 5"," 6"," 7"," 8"," 9","10","11","12","13","14","15","16","17","18","19","20","21","22","23","24","25","26","27","28") length 3
Dim dy,mdow$(7) =("SUN","MON","TUE","WED","THR","FRI","SAT") length 3
'relay hardware pins and vars
Dim rstat(4) = (1,1,1,1) 'rstat stat 1=off 0=on
Dim relay(4) = (10,9,7,6) 'relay pins
Dim ry
'preset relays to off
For ry=1 To 4
' Pin(relay(ry)) = 1
' SetPin relay(ry),dout,oc
Next ry
' Flow switches
Dim FW12 = 4, FW34 = 5, P26 = 26
'flow switch status 1 = off 0 = on
' SetPin FW12, din
' SetPin FW34, din
' SetPin p26, ain
'just throw some values in them
tx=0:ty=8
itx=15:ity=16
itx2=63:ity2=64
icx=127:icy=128
row=5:srow=8:col=6
I2CScanner ' get a sub var test in here to show the locals here don't show
showvar ' but the ones here do
End
Sub clr
Print Chr$(27)+"[f" : Print Chr$(27)+"[2J"
End Sub
Sub locate x,y
Print Chr$(27)+"["+Str$(X)+";"+Str$(Y)+"f";
End Sub
Sub I2CScanner
Local found, i, temp
found=0
Print "I2C-Scanner from Adr. 8-119":Print:Print
For i = &h08 To &h77 ' gueltige I2C-Adressen von 8-119
I2C open 100, 1000 ' i2c enable 100kHz, 1000ms timeout
I2C read i, 0, 1, temp
' Print i;">"; MM.I2C " ";
If MM.I2C = 0 Then
Print:Print:Print "Found I2C-Address at "; i; " ("dec2hex$(i)+")"
found=1
EndIf
I2C close ' i2c disable
Next i
If found = 0 Then Print:Print:Print "NO I2C-Address found!"
End Sub
Function dec2hex$(number) ' used by I2C-Scanner
dec2hex$ = "&H"+ Hex$(number)
End Function
Sub showvar
Local g,n,p,ascii$,last=137
For g=0 To 63 'look through upto 64 variables
ascii$=""
For n = 0 To 31
p=Peek(VARTBL,n+g*64)
If p=0 Then Exit For 'build variable name (end at chr$(0))
Select Case Chr$(p)
Case "A" To "Z","0" To "9"
ascii$=ascii$+Chr$(p)
End Select
Next n
Print Str$(g,2);" ";ascii$;" ",
Print Hex$(Peek(VARTBL,32+g*64),2);" "; ' type 1 is number 2 is string not sure what anything else is
Print Hex$(Peek(VARTBL,33+g*64),2);" "; ' level sub / func ????
Print Hex$(Peek(VARTBL,35+g*64),2);Hex$(Peek(VARTBL,34+g*64),2);" "; ' looks like 8 levels of dimensions
Print Hex$(Peek(VARTBL,37+g*64),2);Hex$(Peek(VARTBL,36+g*64),2);" "; ' seems I can only use the 7 them ??
Print Hex$(Peek(VARTBL,39+g*64),2);Hex$(Peek(VARTBL,38+g*64),2);" ";
Print Hex$(Peek(VARTBL,41+g*64),2);Hex$(Peek(VARTBL,40+g*64),2);" ";
Print Hex$(Peek(VARTBL,43+g*64),2);Hex$(Peek(VARTBL,42+g*64),2);" ";
Print Hex$(Peek(VARTBL,45+g*64),2);Hex$(Peek(VARTBL,44+g*64),2);" ";
Print Hex$(Peek(VARTBL,47+g*64),2);Hex$(Peek(VARTBL,46+g*64),2);" ";
Print Hex$(Peek(VARTBL,49+g*64),2);Hex$(Peek(VARTBL,48+g*64),2);" ";
Print Hex$(Peek(VARTBL,50+g*64),2);" "; ' size ??
For n=51 To 55
Print Hex$(Peek(VARTBL,n+g*64),2);" ";
Next n
Print " ";
Print Hex$(Peek(VARTBL,59+g*64),2);Hex$(Peek(VARTBL,58+g*64),2);
Print Hex$(Peek(VARTBL,57+g*64),2);Hex$(Peek(VARTBL,56+g*64),2);" ";' little e address and/or ????
For n=60 To 63
Next n
Print
If ascii$="LAST" Then Exit For
Next g
Print "test ";Hex$(Peek(VARADDR test()))
Print "fn ";Hex$(Peek(VARADDR fn))
Print "r$ ";Hex$(Peek(VARADDR r$()))
Print "rstat ";Hex$(Peek(VARADDR rstat()))
Print "relay ";Hex$(Peek(VARADDR relay()))
Print "last ";Hex$(Peek(VARADDR last))
End Sub
The 170 is a great worker and with a large pool for r/w nonvolatile memory
many things like having lib's stacked up in it and pulling in whats functions
are needed at the time. Can extend the language with added customized functions.
No need to add new functions to the main MMBasic code. Have scratch pad ram
area and move lib's in as needed. Then we can as a community create a very
large library base of functions.
I will post my attempts as I get more information. As it is always good to
have many eyes and minds go over ones code and thinking process.
Thanks to all that have added code here at TBS It really helps to see
the back and forth of many and their ideas of how a piece code works.
Quazee
Posted: 08:06am 05 Jun 2018
  Quote  What is the structure of the vartbl ?
#define T_NOTYPE 0 // type not set or discovered
#define T_NBR 0x01 // number (or float) type
#define T_STR 0x02 // string type
#define T_INT 0x04 // 64 bit integer type
#define T_PTR 0x08 // the variable points to another variable's data
#define T_IMPLIED 0x10 // the variables type does not have to be specified with a suffix
#define T_CONST 0x20 // the contents of this variable cannot be changed
struct s_vartbl { // structure of the variable table
char name[MAXVARLEN]; // variable's name
char type; // its type (T_NUM, T_INT or T_STR)
char level; // its subroutine or function level (used to track local variables)
short int dims[MAXDIM]; // the dimensions. it is an array if the first dimension is NOT zero
unsigned char size; // the number of chars to allocate for each element in a string array
union u_val {
MMFLOAT f; // the value if it is a MMFLOAT
long long int i; // the value if it is an integer
MMFLOAT *fa; // pointer to the allocated memory if it is an array of floats
long long int *ia; // pointer to the allocated memory if it is an array of integers
char *s; // pointer to the allocated memory if it is a string
} val;
MAXVARLEN is 32
MAXDIM is 8
MMFLOAT is length 4 for MX170 and 8 for MM+ (latest releases only, otherwise 4)
short ints are length 2Edited by matherp 2018-06-06
Quazee137
Posted: 02:24pm 05 Jun 2018
Thank You mattherp. I also got information from Geoff.
So now off to see what I can do with it all.
MAXVARLEN is 32
MAXDIM is 8
really helps
