Local Time 06:46 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with "TEMPR" and Array,s ! BUG ?
PicFan
Posted: 09:17am 05 Jun 2018
The problem concerns the MM-plus V5.04.04 - V5.04.09 BETA 19, as well as MZ V5.04.14! Please try the following:
The mistake is not the temperature value, which is correct, but the array (the_ARR (2,2)) is overwritten!
option explicit
option default integer
dim the_Arr(3,8)
dim float mt
the_Arr(2,2) = 55
do
the_Arr(2,2) = 55
'tempr start 42
print "STA "the_Arr(2,2)
pause 2000
'mt = tempr(42)
print "END "the_Arr(2,2)
loop
OUTPUT:
STA 55
END 55
STA 55
END 55
. . . uncomment the "tempr" commands
option explicit
dim the_Arr(3,8)
dim float mt
the_Arr(2,2) = 55
do
the_Arr(2,2) = 55
tempr start 42
pause 2000
mt = tempr(42)
loop
OUTPUT:
STA 1254003
END 0
STA 1256003
END 0
STA 1258003
END 0
STA 1260003
The value that is erroneously written into the array is the TIMER-Value + 2000! (PAUSE 2000)
I can only reproduce the error with this array dimension (3, x) and only on index (2, x)!
The error does not occur with the MM170 with V5.04.08!
Thank you and best regards from Austria !
WolfgangEdited by PicFan 2018-06-08
rentner111
Posted: 03:31pm 06 Jun 2018
It is a BUG !!
The BUG also occurs on my PIC 32MX470F512 version 5.04.09, and is reproducible at any time.
The value of Arr (2,2) is overwritten with another value by the "tempr start" command.
The value probably comes from a timer.
The command "tempr" then writes the value "00" into Arr (2,2).
This error occurs only at Arr (2,2).
Please answer.
Even the very useful function "continue" does not work reliably anymore.
Many thanks from Austria-Tyrol.
Posted: 11:48am 07 Jun 2018
I've found a temporary workround . Limit the use of pin numbers for the DS18B20 to less than 32
option explicit
dim the_Arr(3,8)
dim float mt
the_Arr(2,2) = 55
do
the_Arr(2,2) = 55
tempr start 22
pause 2000
mt = tempr(22)
loop
Works fine - I've emailed Geoff with the fixEdited by matherp 2018-06-08
