Local Time 05:51 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Numberbox
macca
Posted: 11:38am 05 Jun 2018
Hi to all
I have two pages and on the second page there is a numberbox. On entering a number in the numberbox (Page 2) is there a way to print the results of the numberbox on page 1
regards
panky
Posted: 04:19am 06 Jun 2018
John,
One way would be to create a DISPLAYBOX on page 1 of the size and position where you want to display the numberbox details then where you action your numberbox on page 2, add in the line to assign the value of the numberbox to the display box.
eg. The following code gives you an example
CLS
GUI INTERRUPT TouchDown,TouchUp
InitPages
font 3
DO
PAGE 1
' FONT 3
TEXT 0,0,"doing something on page 1"
PAUSE 4000 ' wait a little bit
PAGE 2
' FONT 3
TEXT 0,0, "Enter a number in the box and press enter"
DO
LOOP UNTIL NumBoxEnter = 1 ' wait till Numberbox Enter pressed
NumBoxEnter = 0
TEXT 0,0, " fall back to page 1 showing number"
PAUSE 3000
CTRLVAL(#1) = "Number entered was "+STR$(CTRLVAL(#2)) ' plug numberbox value into displaybox
LOOP
SUB InitPages ' doesn't have to be a sub as it is called only once
' but does make it easier to read and understand
GUI SETUP 1 ' your page 1
FONT 3
GUI DISPLAYBOX #1, 100,100,400,60,RGB(WHITE),RGB(BLACK)
' note does not have to be in the same position as the numberbox below
GUI SETUP 2 ' your page 2
FONT 3
GUI NUMBERBOX #2,100,100,150,60,RGB(WHITE),RGB(BLACK)
END SUB
SUB TouchDown
'not used for this demo
END SUB
SUB TouchUp ' numberbox Enter pressed
NumBoxEnter = 1
END SUB
macca
Posted: 01:50pm 06 Jun 2018
Hi and thank you panky for your reply
I will play around with this tomorrow.
Cold wet and miserable here in the west
regards
panky
Posted: 11:19pm 06 Jun 2018
John,
Anywhere near Mount Barker? Have a brother there who is an MM wizard (bit shy, not on the backshed yet)
panky
macca
Posted: 02:20am 07 Jun 2018
No I live in Merredin on the Great Eastern Highway about 265K from Perth. I also was a bit shy and finally made the jump to join the backshed. Great sources of information and the people are friendly and very helpful.
Best regards
macca
Posted: 02:37pm 12 Jun 2018
Hi to all
Code below
How can I get the number box results on page 2 to show in the box on page 1.
Sorry Panky but I am bit confused at this stage, Maybe I am going about this in the wrong way??
'Pages
cls
Const frm_ind = 20: frm_out = 22:frm_hpa = 23
Const frm_log = 40, cb_enabled = 41, c_fname = 42, tb_fname = 43
Const c_log = 44, cb_flow = 45, cb_alarm = 48, cb_warn = 49
Const frm_alarm = 50, nbr_hi = 51, nbr_lo = 52
Const c_hi = 54, c_lo = 55
Const led_high = 56, led_low = 57
Const c_bright = 58, sb_bright = 59
Const frm_logs = 61, c_det = 63, c_head = 62, c_al = 64
' Page 1
Gui Setup 1
Font 2,2
GUI DISPLAYBOX #1,0,0,MM.HRES,75,RGB(yellow),RGB(Black)
CtrlVal(#1)="Page 1"
Font 2,1
GUI button 11,"1",50,400,100,30,RGB(black),RGB(gray)' button 1
Font 2,1
GUI CAPTION #4,"Page 2",55,380,LT,RGB(green)
GUI CAPTION #25,"Temp High",320,195,LT,RGB(green)
' Display box showing high temp settings
GUI DISPLAYBOX #66, 450, 190, 75, 30,RGB(yellow),RGB(Black)
GUI Setup 2
Font 2,1
Colour RGB(cyan), 0
'alarm frame
font 3,1
GUI Caption c_head, "Page 2", 320, 50,, RGB(80, 200, 120)
Font 2
GUI Caption c_al, "Set Alarm Temp", 85, 130,, RGB(237, 145, 33)
GUI Caption c_hi, "Temp High:", 70, 175,, RGB(yellow)
GUI Numberbox nbr_hi, 195, 170, 60, 30, RGB(yellow),RGB(64,64,64) ' Set the high temp alarm
GUI button 16,"EXIT",50,380,120,50,RGB(blue),RGB(gray) ' Back to page 1
GUI INTERRUPT PenDown
page 1
DO:LOOP
SUB pendown
SELECT CASE TOUCH(REF)
print touch(REF)
CASE 11
page 2 ' touch for page 2
CASE 16
page 1
END SELECT
EXIT SUB
Not sure if this is the way to show code
panky
Posted: 02:49am 13 Jun 2018
Macca,
The GUI NUMBERBOX command generates 2 interrupts, a TouchDown when the NUMBERBOX is first selected and a TouchUp interrupt when the Ent key on the on-screen number box display is pressed.
The on-screen numberbox ENT key also sets the number entered into the control value. Thus, in a second subroutine for TouchUp, you would assign the values from the NUMBERBOX CTRLVAL to a variable.
It is also usefull to set a flag in both routines to allow you to test in your main program loop. When checked, the flags should be cleared ready for the next touch.
eg.
Initialise: ' do all setup functions here
Main: ' main program loop
DO
' if you want to wait on a touch to do something
DO
LOOP UNTIL TouchDownFlag = 1
IF TouchDownFlag = 1 THEN
' process the touch down action with SELECT CASE subroutines
SELECT CASE TOUCH(REF) ' which ctrlval used?
CASE 1
value_in_ctrlval_1 = CTRLVAL(1)
' etc, etc for any other number boxes
END SELECT
TouchDownFlag = 0 ' reset ready for next touch
ENDIF
IF TouchUpFlag = 1 THEN
' process the touch action with SELECT CASE subroutines
SELECT CASE TOUCH(REF) ' which numberbox used?
CASE numberbox_1
value_in_numberbox_1 = CTRLVAL(number_box_1)
END SELECT
TouchUpFlag = 0 ' reset for next numberbox touch
ENDIF
' do whatever else needs to be done in your main program loop
LOOP
SUB TouchDown
' blah blah, anything else needing to be done with a touchdown
TouchDownFlag = 1
END SUB
SUB TouchUp
TouchUpFlag = 1
END SUB
This is just an idea and sample code - it will need to be modified for your particular program.
Hope this helps,
panky
