Local Time 06:46 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PWM Channel, STOP Query
Chopperp
Posted: 06:07am 10 Jun 2018
As an aside to Zonker's post on PWM, can anyone tell me why the PWM STOP code within the loop prevents the actual PWM code from working. Place it outside the loop & it works as expected.
I can't see that I am doing anything wrong.
option autorun on
do
for x = 1 to 9
'pwm 1,stop 'Loop does not work with this enabled
width = x * 10
pause 1000
pwm 1, 100, width
next x
pwm 1,stop 'Loop works with this enabled
loop
ChopperP
Posted: 06:55am 10 Jun 2018
With it in the loop you will do this:
1. at x=1, start the pwm
2. at x=2 (about 10uS later or so) you will stop the PWM
and so on.
So it is working but you immediately stop it as there is no time delay between loops.
Chopperp
Posted: 07:37am 10 Jun 2018
Thanks John.
Works with the pause moved down a bit.
ChopperP
