Local Time 05:53 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Multi Page GUI Example
panky
Posted: 03:09am 13 Jun 2018
Hi folks,
I have been playing around with GUI controls for some months now and after quite a bit of head scratching have come up with a framework for a multi page GUI display example - it does nothing other than show how multiple pages may be created and used.
I hope it may be of use as a reference on one way in which multiple pages may be used and displayed (I make no claim to it being the best or only way - it is just an example).
It will run standalone on a 470 with an SSD 1963 7" display. If anyone is interested, I also have a similar version on a 2.8" ILI display.
Hope it is of interest and useful to someone.
panky
' Universal Function Controller Interface '
' Written by Doug Pankhurst May 2017, based on coding '
' ideas from Tom Pankhurst and '
' various other Back Shed Forum members - thanks. '
' Written for MMBasic V5.4.09 , copyright Geoff Graham 2012 '
' Program runs on PIC32MX470 with an SSD1963 7" touch screen '
' This program is free for anyone to use or modify as they '
' choose however, if you wish to re-distribute, please '
' acknowledge authors and contributors above. '
' File Version TSetSSD006.bas 10 June 2018
' Notes:
' running on MMBasic V5.04.09B19
' - last known good version
' Initial Entry to Program
EntryPoint:
SetTick 0,0 ' Disable timer interrupt for now
Option explicit
' Option autorun on
' Define constants for gui controls
' ILI display is 320 x 240
const BGround_Box = 10
Const Head_Box = 11
const Back_Arrow_Box = 12 ' back arrow box
const Help_Button_Box = 13 ' question mark box
const Hint1_Box = 14
const Intro_Box = 15 ' initial introduction
const Info_Box= 16 ' used for help messages
const PTSwitch_Box = 17
const TimeSwitch_Box = 18
const TempSwitch_Box = 19
const RisingEdgeRB = 20
const FallingEdgeRB = 21
const HiLevelRB = 22
const LoLevelRB = 23
const TriggerSelRB = 24
const TimerOnTimeNB = 25 ' duration of "on" time
const TrigHoldOffNB = 26 ' debounce from edge
const DecHrsNB = 27
const OffTimeDelayNB = 28
const TimerOnTimeF = 29
const OffTimeDelayF = 30
const HoldOffF = 31
const HoldOffNB = 32
const RelaySelF = 33
const Relay1RB = 34
const Relay2RB = 35
const Relay3RB = 36
const TODStartF = 37
const TODEndF = 38
const TODStartDB = 39
const TODEndDB = 40
const HiTempF = 41
const LoTempF = 42
const THoldOffF = 43
const HiTempNB = 44
const LoTempNB = 45
const THoldOffNB = 46
const TempTrigF = 47
const TempALoRB = 48
const TempBLoRB = 49
const TempAHiRB = 50
const TempBHiRB = 51
' touch areas for display boxes - these must have a lower control
' value than any thing they overlay.
const Back_Arrow_Touch = 1
const Help_Button_Touch = 2
const Hint1_Touch = 3
const PTSwitch_Touch = 4
const TimeSwitch_Touch = 5
const TempSwitch_Touch = 6
' other constants
'Define variables
' Global Variables - initialised to default values
Dim F_Ver = 0.06 ' File Version TSetSSD006.bas 10 June 2018
' Voltage and current of caravan battery
' misc variables
dim Help$ ' string to display in help box
dim ActiveScreen = 1 'default to main GUI page
Dim Ax 'loop counter
dim S_Bright = 40 ' initial display brightness
dim delim$ = "," ' delimiter for field extract
dim n_field = 1 ' number of field in front end data stream
dim hrs,mins,secs,dom ' used in calculating time flags
dim Instruct$ ' use with Hint_1 display box
dim IntroMsg$ ' startup message
dim Trigger = 0 ' 1 rising edge, 2 falling edge, 3 HiLevel, 4 LoLevel
dim TimerOnTime ' duration of "on" time in decimal minutess
dim HoldOffDelay ' debounce the input edge in mSecs
dim OffTimeDelay ' delay before next cycle can begin
dim TODStart$ ' start time for TOD counter
dim TODEnd$ ' end time for TOD counter
dim TODStartSecs ' referenced to previous midnight
dim TODEndSecs ' referenced to previous midnight
dim LCDScale 2 ' SSD is 2 times ILI
dim LCDType = 2 ' 1 is ILI, 2 is SSD
' Flags
Dim NewDataFlag = 0 ' Two second flag - set every
dim TouchDetected = 0 ' flag touch
dim StartAction = 1 ' used as initiator of timer action
dim InsideNB = 0 ' set when inside a NumberBox, cleared on Enter
' Carry out initialisation routines here - enable interrupt last
StartPoint:
cls
backlight 50
GUI interrupt TouchDown,TouchUp ' subroutine to handle touch int
InitGUI ' routine to set GUI controls
' preset some display boxes
CtrlVal(Head_Box) = "Function Controller"
ctrlval(Back_Arrow_Box) = "<" ' left arrow
ctrlval(Help_Button_Box) = "?" ' home
' preset some variables
IntroMsg$ = "Function Controller v"+str$(F_ver)+" "
IntroMsg$ = IntroMsg$ + "~Created by D.Pankhurst~"
IntroMsg$ = IntroMsg$ + "Select < to goto main menu~~"
IntroMsg$ = IntroMsg$ + "Tap header to increase brightness"
ctrlval(Intro_Box) = IntroMsg$
' ctrlval(Hint_1) = "Press for menu"
' Display all static data
ActiveScreen = 1
UpdateGUIScreen ' setup initial screen
UpdateGUIVals
TouchDetected = 0
' Initialise interrupts
Main:
Do 'Main program loop,
Do While TouchDetected = 0 ' wait until data request sent
' should only get here if touch detected
if InsideNB = 0 then
UpdateGUIScreen
UpdateGUIVals
TouchDetected = 0
else
endif
' end of main process loop
' main data processing subroutines
' Interrupt handling subroutines
' - screen touch routines for GUI interface
Sub TouchDown
Select Case Touch(REF)
Case Help_Button_Touch ' ? Button
ActiveScreen = 9
Case Hint1_Touch ' Hint box
ActiveScreen = 2 ' info screen
Case Back_Arrow_Touch ' < Button
ActiveScreen = 3 ' Main menu screen
case PTSwitch_Touch ' select period timer
ActiveScreen = 4 ' Period Timer screen
' StartAction = 1
case TimeSwitch_Touch ' select time of day timer
ActiveScreen = 5 ' Period Timer screen
' StartAction = 1
case TempSwitch_Touch ' select temperature controller
ActiveScreen = 6 ' temperature controller screen
' StartAction = 1
case TimerOnTimeNB '
InsideNB = 1
' ActiveScreen = 6
case OffTimeDelayNB '
InsideNB = 1
' ActiveScreen = 6
case HoldOffNB '
InsideNB = 1
' ActiveScreen = 6
Case Else ' anywhere else on screen to change brightness
' .. may nedd to define a particular area
If S_Bright < 100 then
S_Bright = S_Bright + 2 ' adjust steps to suit
else
S_Bright = 0
endif
backlight S_Bright
End Select
TouchDetected = 1
End Sub ' end of touch down subroutine
sub TouchUp
InsideNB = 0 ' was inside a NumberBox
End sub
'End of Interrupt handling routines
sub UpdateGUIScreen ' control multiple page display
select case ActiveScreen
case 1 ' default base screen with intro message
page 1,2
CtrlVal(Head_Box) = "Universal Timer"
ctrlval(Hint1_Box) = "Press for Main Menu"
case 2 ' info screen
page 1,3
CtrlVal(Head_Box) = "Main Menu"
CTRLVAL(PTSwitch_Box) = "Period~Timer"
CtrlVal(TimeSwitch_Box) = "TOD~Timer"
CtrlVal(TempSwitch_Box) = "Temp~Timer"
ctrlval(Hint1_Box) = "Select Menu Option"
case 3
page 1,3
case 4
page 1,4,7,8
ctrlval(Hint1_Box) = "Press to Start"
CtrlVal(Head_Box) = "Period Timer"
TimerOnTime = ctrlval(TimerOnTimeNB)
OffTimeDelay = ctrlval(OffTimeDelayNB)
HoldOffDelay = ctrlval(HoldOffNB)
case 5
page 1,5,7,8
CtrlVal(Head_Box) = "TOD Timer"
case 6
page 1,6,8,10
CtrlVal(Head_Box) = "Temperature Timer"
case 7
case 8
case 9
CtrlVal(Info_Box) = "Help Help Help~~Help Help Help"
page 1,9
case else
end select
End sub
sub UpdateGUIVals
case 2 '
case 3
case 4
case 5
case 6
case 7
case 8
case 9
case else
end select
end sub
' GUI Setup routine - only called once on startup but safer in a subroutine
' values here are for an SSD1963 7" LCD
sub InitGUI ' initialise graphics
gui setup 1 ' same for all pages
Font 3,2
GUI displaybox Head_Box,0,0,800,80,RGB(white),RGB(25,100,215)
font 3,2
GUI Displaybox Back_Arrow_Box,0,400,80,80,RGB(black),RGB(220,220,255)
GUI Displaybox Help_Button_Box,720,400,80,80,RGB(black),RGB(220,220,255)
font 2,2
GUI displaybox Hint1_Box,90,400,620,80,RGB(black),RGB(white)
GUI area Back_Arrow_Touch,0,400,80,80 '
GUI area Help_Button_Touch,720,400,80,80 '
GUI area Hint1_Touch,90,400,620,80 '
GUI setup 2 ' intro box
rbox 0,90,800,300,,RGB(black),RGB(210,230,210) ' empty area for below
font 2
gui displaybox Intro_Box,0,90,800,300,RGB(black),RGB(210,230,210) '
gui setup 3 ' main menu area
rbox 0,90,800,300,,RGB(black),RGB(210,230,210) ' empty area for menu switches below
font 2,2
GUI DISPLAYBOX PTSwitch_Box,0,90,180,90,RGB(black),RGB(green)
GUI DISPLAYBOX TimeSwitch_Box,0,190,180,90,RGB(black),RGB(magenta)
GUI DISPLAYBOX TempSwitch_Box,0,290,180,90,RGB(black),RGB(cyan)
gui area PTSwitch_Touch,0,90,180,80
gui area TimeSwitch_Touch,0,190,180,80
gui area TempSwitch_Touch,0,290,180,80
gui setup 4 ' period timer
font 3
gui frame TimerOnTimeF,"On Time S",0,100,200,70,rgb(white)
gui frame OffTimeDelayF,"Off Time S",0,210,200,70,rgb(white)
gui frame HoldOffF,"HoldOff mS",0,320,200,70,rgb(white)
gui numberbox TimerOnTimeNB,10,120,180,40,rgb(red),rgb(Black)
gui numberbox OffTimeDelayNB,10,230,180,40,rgb(red),rgb(Black)
gui numberbox HoldOffNB,10,340,180,40,rgb(red),rgb(Black)
gui setup 5 ' time of day switch
font 3
gui frame TODStartF,"Start Time~HH:MM:SS",0,120,210,100,rgb(white)
gui frame TODEndF,"End Time~HH:MM:SS",0,280,210,100,rgb(white)
gui textbox TODStartDB,10,160,190,50,rgb(red),rgb(Black)
gui textbox TODEndDB,10,320,190,50,rgb(red),rgb(Black)
gui setup 6 ' temperature switch
font 3
gui frame LoTempF,"Lo Temp C",0,100,200,70,rgb(white)
gui frame HiTempF,"Hi Temp C",0,210,200,70,rgb(white)
gui frame THoldOffF,"HoldOff C",0,320,200,70,rgb(white)
gui numberbox LoTempNB,10,120,180,40,rgb(red),rgb(Black)
gui numberbox HiTempNB,10,230,180,40,rgb(red),rgb(Black)
gui numberbox THoldOffNB,10,340,180,40,rgb(red),rgb(Black)
gui setup 7 '
font 3
gui frame TriggerSelRB,"Trigger",220,100,210,290,rgb(white)
GUI RADIO RisingEdgeRB, "Rising~Edge",260,150,15,rgb(Blue)
GUI RADIO FallingEdgeRB, "Falling~Edge",260,220,15,rgb(Blue)
GUI RADIO HiLevelRB, "Hi~Level",260,290,15,rgb(Blue)
GUI RADIO LoLevelRB, "Lo~Level",260,360,15,rgb(Blue)
gui setup 8 '
font 3
gui frame RelaySelF,"Relays",440,100,200,290,rgb(white)
GUI RADIO Relay1RB, "RLY 1",480,150,15,rgb(Blue)
GUI RADIO Relay2RB, "RLY 2",480,220,15,rgb(Blue)
GUI RADIO Relay3RB, "RLY~1,2,3",480,290,15,rgb(Blue)
gui setup 9 ' help screen
font 2
GUI Displaybox Info_Box,0,90,800,300,RGB(black),RGB(210,230,210)
gui setup 10 '
font 3
gui frame TempTrigF,"Trigger",220,100,210,290,rgb(white)
GUI RADIO TempALoRB, "Temp~> Lo",260,150,15,rgb(Blue)
GUI RADIO TempBLoRB, "Temp~< Lo",260,220,15,rgb(Blue)
GUI RADIO TempAHiRB, "Temp~> Hi",260,290,15,rgb(Blue)
GUI RADIO TempBHiRB, "Temp~< Hi",260,360,15,rgb(Blue)
' end of GUI setups
end sub
function HMS2Secs(arg1$,arg2)
local HMSTime$,SecsTime,hh,mm,ss)
HMTime$ = arg1$
hh = val(Field$(HMTime$,1,":"))
mm = val(Field$(HMTime$,2,":"))
ss = val(Field$(HMTime$,3,":"))
SecsTime
HMS2Secs = (hh*3600)+(mm*60)+ss
end function
' Geoff's Message Field$ Routine (with one amendment
' by CaptainBoing)
Function Field$(DataVals$,n_field,delim$)
Local Integer i, StartIdx = 1, EndIdx
local dv$ length 64
' enter with DataVals$ with 9 fields in the form
' BVolts,SVolts,CVolts,SAmps,CAmps,ACAmps,DCAmps,LAmps,"zz.zz"
' note always 9 fields but field length may vary
' with 9th field a pseudo checksum as "zz.zz"
dv$ = DataVals$
' get the start of the field in StartIdx
For i = 2 To n_field
StartIdx = Instr(StartIdx, dv$, delim$) + 1
If StartIdx = 1 Or StartIdx > Len(dv$) Then
Exit Function
endif
Next i
' get the end of the field in EndIdx and extract the field
EndIdx = Instr(StartIdx, dv$, delim$)
If EndIdx = 0 Then
EndIdx = Len(dv$)+1 ' makes it smaller than 255
endif
Field$ = Mid$(dv$, StartIdx, EndIdx - StartIdx)
End Function
' End program.
RonnS
Posted: 08:15am 13 Jun 2018
Panky
Many thanks for sharing your work, i will test it with the picromite and a 3.5 or 4 inch display.
I have my problems with coding the pages
Did you take pictures ?
thanks Ron
panky
Posted: 09:11am 13 Jun 2018
Hi Ron,
The positioning for all the elements is for an 800 x 480 display so the are a lot of changes needed for smaller displays. I will post a version for 320 x 240 dimension display later tonight (tested on a 2.4" ILI display). It should run on any larger size display.
I will also post a couple of pics. Again, this is just a framework for anyone to use for there own project - it doesn't actually do anything other than show a multi page menu system.
panky.
Edited by panky 2018-06-14
panky
Posted: 10:02am 13 Jun 2018
The following code will run on a 470 with an 2.8" ILI display (320 x 240)
It doesn't have the code for processing the Temperature Timer option but the code from the first post could be plugged in (or any other functions in fact).
Cheers,
panky
' Program runs on PIC32MX470 with an ILI 2.8" touch screen '
' Notes:
EntryPoint:
Option explicit
' Option autorun on
Const Head_Box = 11
const DecHrsNB = 27
const HoldOffF = 31
const Relay1RB = 34
const Relay2RB = 35
const Relay3RB = 36
const TODEndF = 38
const TODEndDB = 40
const HiTempF = 41
const LoTempF = 42
const HiTempNB = 44
const LoTempNB = 45
' other constants
'Define variables
' misc variables
' Flags
StartPoint:
backlight 50
ActiveScreen = 1
UpdateGUIVals
TouchDetected = 0
Main:
UpdateGUIScreen
UpdateGUIVals
TouchDetected = 0
else
endif
Sub TouchDown
ActiveScreen = 9
' StartAction = 1
' StartAction = 1
' StartAction = 1
InsideNB = 1
' ActiveScreen = 6
InsideNB = 1
' ActiveScreen = 6
case HoldOffNB '
InsideNB = 1
' ActiveScreen = 6
else
S_Bright = 0
endif
backlight S_Bright
End Select
TouchDetected = 1
sub TouchUp
End sub
page 1,2
page 1,3
case 3
page 1,3
case 4
page 1,4,7,8
case 5
page 1,5,7,8
case 6
page 1,6,8,10
case 7
case 8
case 9
page 1,9
case else
end select
End sub
sub UpdateGUIVals
case 2 '
case 3
case 4
case 5
case 6
case 7
case 8
case 9
case else
end select
end sub
Font 3,2
font 3,2
font 2,2
font 2
font 2,2
font 3
font 3
font 3
gui setup 7 '
font 3
gui setup 8 '
font 3
font 2
gui setup 10 '
font 3
' end of GUI setups
end sub
HMTime$ = arg1$
SecsTime
end function
' by CaptainBoing)
local dv$ length 64
dv$ = DataVals$
Exit Function
endif
Next i
If EndIdx = 0 Then
endif
End Function
' End program.
SteveA
Posted: 08:09am 14 Jun 2018
  Quote  The following code will run on a 470 with an 2.8" ILI display (320 x 240)
Sorry, it doesn't.
There are references to dimensions greater than 320 x 240 in the code, I think you may have inadvertently uploaded the wrong file?
Rgds,
Steve
panky
Posted: 09:24am 14 Jun 2018
My apologies to all - the code was for an SSD display as SteveA pointed out.
The following code was tested on a Sil Chip MM+ Backpack with a 2.8" display and it did run. Copied from here to MMEdit and downloaded to the MM+.
NOTE: This is a 'proof of concept' program and may have errors - I was merely trying to offer some suggestions and an example of how a multi page menu based GUI program might be implimented. The Temp Timer does nothing at present - it is just a frame to do whatever you want to with.
panky
' Universal Function Controller '
' Program runs on PIC32MX470 with an ILI9361 2.8" touch screen'
' File Version TSetILI004.bas 6 June 2018
' Notes:
EntryPoint:
Option explicit
' Option autorun on
Const Head_Box = 11
const DecHrsNB = 27
const HoldOffF = 31
const Relay1RB = 34
const Relay2RB = 35
const Relay3RB = 36
const TODEndF = 38
const TODEndDB = 40
const TODStart_Touch = 7
const TODEnd_Touch = 8
' other constants
'Define variables
Dim F_Ver = 0.04 ' File Version TSetILI004.bas 6 June 2018
' misc variables
' Flags
StartPoint:
pwm 2,1000,S_Bright
' backlight 50
ActiveScreen = 1
UpdateGUIVals
TouchDetected = 0
Main:
UpdateGUIScreen
UpdateGUIVals
TouchDetected = 0
else
endif
Sub TouchDown
ActiveScreen = 9
' StartAction = 1
' StartAction = 1
' StartAction = 1
InsideNB = 1
' ActiveScreen = 6
InsideNB = 1
' ActiveScreen = 6
case HoldOffNB '
InsideNB = 1
' ActiveScreen = 6
S_Bright = S_Bright + 10
else
S_Bright = 0
endif
pwm 2,1000,S_Bright
' backlight = S_Bright
End Select
TouchDetected = 1
sub TouchUp
End sub
page 1,2
page 1,3
case 3
page 1,3
case 4
page 1,4,7,8
case 5
page 1,5,7,8
case 6
page 1,6
case 7
case 8
case 9
page 1,9
case else
end select
End sub
sub UpdateGUIVals
case 2 '
case 3
case 4
case 5
case 6
case 7
case 8
case 9
case else
end select
end sub
Font 2
GUI displaybox Head_Box,0,0,320,40,RGB(white),RGB(25,100,215)
font 3
GUI Displaybox Back_Arrow_Box,0,200,40,40,RGB(black),RGB(220,220,255)
GUI Displaybox Help_Button_Box,280,200,40,40,RGB(black),RGB(220,220,255)
font 2
GUI displaybox Hint1_Box,45,200,230,40,RGB(black),RGB(white)
GUI area Back_Arrow_Touch,0,200,40,40 '
GUI area Help_Button_Touch,280,200,40,40 '
GUI area Hint1_Touch,50,200,220,40 '
rbox 0,45,320,150,,RGB(black),RGB(210,230,210) ' empty area for below
font 1
gui displaybox Intro_Box,0,45,320,150,RGB(black),RGB(210,230,210) '
rbox 0,45,320,150,,RGB(black),RGB(210,230,210) ' empty area for menu switches below
font 1
GUI DISPLAYBOX PTSwitch_Box,0,45,90,45,RGB(black),RGB(green)
GUI DISPLAYBOX TimeSwitch_Box,0,95,90,45,RGB(black),RGB(magenta)
GUI DISPLAYBOX TempSwitch_Box,0,145,90,45,RGB(black),RGB(cyan)
gui area PTSwitch_Touch,0,45,90,40
gui area TimeSwitch_Touch,0,95,90,40
gui area TempSwitch_Touch,0,145,90,40
font 1
gui frame TimerOnTimeF,"On Time S",0,50,100,35,rgb(white)
gui frame OffTimeDelayF,"Off Time S",0,105,100,35,rgb(white)
gui frame HoldOffF,"HoldOff mS",0,160,100,35,rgb(white)
gui numberbox TimerOnTimeNB,5,60,90,20,rgb(red),rgb(Black)
gui numberbox OffTimeDelayNB,5,115,90,20,rgb(red),rgb(Black)
gui numberbox HoldOffNB,5,170,90,20,rgb(red),rgb(Black)
font 1
gui frame TODStartF,"Start Time~HH:MM:SS",0,60,105,50,rgb(white)
gui frame TODEndF,"End Time~HH:MM:SS",0,140,105,50,rgb(white)
gui TEXTbox TODStartDB,5,80,95,25,rgb(red),rgb(Black)
gui TEXTbox TODEndDB,5,160,95,25,rgb(red),rgb(Black)
font 1
gui setup 7 '
gui frame TriggerSelRB,"Trigger",110,50,105,145,rgb(white)
GUI RADIO RisingEdgeRB, "Rising~Edge",130,75,15,rgb(Blue)
GUI RADIO FallingEdgeRB, "Falling~Edge",130,110,15,rgb(Blue)
GUI RADIO HiLevelRB, "Hi~Level",130,145,15,rgb(Blue)
GUI RADIO LoLevelRB, "Lo~Level",130,180,15,rgb(Blue)
gui setup 8 '
gui frame RelaySelF,"Relay",220,50,100,145,rgb(white)
GUI RADIO Relay1RB, "TB1~NC",240,75,15,rgb(Blue)
GUI RADIO Relay2RB, "TB2~NO",240,110,15,rgb(Blue)
GUI RADIO Relay3RB, "TB3~NO",240,145,15,rgb(Blue)
font 1
GUI Displaybox Info_Box,0,45,320,150,RGB(black),RGB(210,230,210)
' end of GUI setups
end sub
HMTime$ = arg1$
SecsTime
end function
' by CaptainBoing)
local dv$ length 64
dv$ = DataVals$
Exit Function
endif
Next i
If EndIdx = 0 Then
endif
End Function
' End program.
