Local Time 05:51 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CLS not working as expected
carlm
Posted: 07:21am 19 Jun 2018
Hi all, I have an issue with a piece(s) of my MM Edit code.
I have attached a chunk of my code for a Micromite backpack.
As you can see i have utilised CLS to clear the screen.
I have commented out my 4 of Drawbutton lines.
Subsequently the buttons are not created.
Problem is that other buttons still appear on my display in runtime.
These buttons are buttons that are created by DrawButtons in other parts of my code. I only want my 4 of buttons here and none else.
My CLS does not seem to work as I would like. I am not sure - the other buttons that appear may be global buttons or the like.
Can anyone help?
Thanks in Advance.
Sub StandbyControl
Local Float btn
CLS
FONT 1, 2
Text 160,15, StandbyTitleA, CM, , , rgb(blue), rgb(black)
'DrawButton bTempLitrePulse , 0, 8, 10, 170, 30, rgb(yellow), "1 L P"
'DrawButton bNavtoWarning, 0, 8, 160, 110, 35, rgb(yellow), "Warn"
'DrawButton bNavtoEmpty, 0, 8, 200, 110, 35, rgb(yellow), "Empty"
'DrawButton bDosesReset, 0, 8, 200, 110, 35, rgb(yellow), "Refill"
Text 4, 55, "Next Dose in:", LM, , , rgb(cyan), rgb(black)
Text 255, 55, "Lt" , LM, , , rgb(cyan), rgb(black)
Text 4, 90, "Since Refill:", LM, , , rgb(cyan), rgb(black)
Text 4, 125, "Warning SP: ", LM, , , rgb(cyan), rgb(black)
Text 4, 160, "Empty SP: ", LM, , , rgb(cyan), rgb(black)
'Text 220,65, " ", LM, , , rgb(cyan), rgb(black)
'Text 220,90, " ", LM, , , rgb(cyan), rgb(black)
''Text 220,125, " ", LM, , , rgb(cyan), rgb(black)
'Text 220,160, " ", LM, , , rgb(cyan), rgb(black)
Text 227, 55, STR$(iLitresPerDose - iPulseCountSinceLastDose) , CM, , , rgb(cyan), rgb(black)
Text 220, 90, STR$(iDosesSinceRefill), LM, , , rgb(cyan), rgb(black)
Text 220, 125, STR$(iDoseCountWarning), LM, , , rgb(cyan), rgb(black)
Text 220, 160, STR$(iDoseCountEmpty), LM, , , rgb(cyan), rgb(black)
Timer = 0
WATCHDOG 20000
CheckButtonPress(1, NumberOfButtons)
'DoseControl
if key_Pulse(bTempLitrePulse) = 1 then
iPulseCountSinceLastDose = iPulseCountSinceLastDose + 1
'iTemp = iLitresPerDose - iPulseCountSinceLastDose
DoseControl
endif
if key_Pulse(bDosesReset) = 1 then
iDosesSinceRefill = 0
Text 220, 90, " ", LM, , , rgb(cyan), rgb(black)
endif
'IF TIMER > 30000 THEN ScreenSaver
LOOP
END SUB
AussieWombat
Posted: 08:32am 19 Jun 2018
Hi carlm,
Welcome to the forum.
Maybe, but not sure , whether the command
GUI HIDE ALL
then
GUI SHOW (#ref first button),(2nd button), etc
might work, when you only want those 4 gui elements on screen.
Page 26 of Micromite Plus Manual 5.1 (edit: Might not relate to Micromite Backpack )
AussieWombatEdited by AussieWombat 2018-06-20
carlm
Posted: 11:34pm 20 Jun 2018
Thanks for that.
I will definitely give that a go.
Carl
Azure
Posted: 11:44pm 20 Jun 2018
That extract you posted is a subroutine.
If your main code or any interrupt driven code updates the screen then that other code will be updating the screen after the CLS command in your subroutine is executed.
You will need to check your program flow by looking at what else gets displayed and find the code which displays it to see when it is updating your screen.
One thing you might be able to do is add a flag to indicate what state your program is in and have the other code check if it is ok to display things or not based on the flag.
Posted: 11:45pm 20 Jun 2018
Welcome to the forums AussieWombat and carlm.
If you are using the Backpack(28-pin chip), that only has basic touch-screen support, so won't acknowledge any of the GUI commands, and it will throw an error along the lines of 'Unknown command'.
GUI commands are specifically for use with the MM+ series of chips.
Explore-64, Explore-100 and matherp's MMX.
Are you using a Micromite Backpack(28-pin DIL chip) or a Micromite Plus Backpack(64-pin QFP SMD chip)?
panky
Posted: 01:00am 21 Jun 2018
Carl,
As said by Grogster above, you are a bit limited with the MM2 if you want to do
a multi page, multi menu type display. This easily achieved by using an MM+ and the GUI commands.
If you end up going this way, please have a look at this thread - it is just an example and not necessarily the only or best way to do this but it may give you some ideas.
panky
