Local Time 04:53 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : HC-12 Logging To OpenLog
Andrew_G
Posted: 08:28am 06 Jul 2018
The next phase of my (MM170) project is to log selected parameters from my HC-12 network (temperatures, pressures, wind and rain) to an OpenLog module.
cDeagle has a number of posts here and here too he may be able to chime in (please).
There is a description of the commands at
I have the module recording OK but I can't issue the commands (ie I can't get it into Command mode)
I have three sets of questions:
1) Connections. I believe the following are correct - can anyone confirm:??
Module----My Guess
BLK-------Ground
GND-------n/c (=CTS)
Vcc-------3V3
TXO-------MM pin 22
RXI--------MM pin 21
GRN-------n/c (=DTR)
2) MM code: It appears to be as simple as Open "COM1:9600" as #2 then Print #2, . . .
3) How to get it into (and then out of) command mode - I specifically want to Reset the Logfile number - it only allows 65533 files.
Thanks,
Andrew
PS: Why am I doing it this way?:
1) I have two OpenLog modules that I want to try
2) I could go straight to my PC from my HC-12 dongle but I don't want the PC running all the time whereas a MM can
3) I could use a MM+ (which I know works) but I only have one and I don't want to tie it up yetEdited by Andrew_G 2018-07-07
