Local Time 03:50 21 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite supplier
miyek.ard
Posted: 01:59am 16 Jul 2018
Hi there, I am sorry to ask this silly question,
But is there any supplier other than White Wizzard that can provide full set of assembled Micromite TFT Backpack? As we all know, WW currently got some personal matter, and I really need the full set as soon as possible.
Thank you for any suggestion!!
Azure
Posted: 02:02am 16 Jul 2018
Which particular MM backpack are you after?
miyek.ard
Posted: 02:06am 16 Jul 2018
Micromite Plus LCD backpack (64 pin)
panky
Posted: 07:05am 17 Jul 2018
Hi miyek.ard,
There are three MM Plus 64 pin backpacks that I am aware of:-
1. A board designed by Peter Mather that has connectors for both an ILI 2.4" or 2.8" display and a SSD1963 4.5", 5" or 7" TFT display. I am not aware of anyone other than WW selling a populated version of this board but you can get bare boards from WW and Circuit Gizmos. Gerbers of this board are available if you wish to get your own boards manufactured.
2. The CGMicroboard 2 from Circuit Gizmos - it has a connector for an ILI 2.4" or 2.8" TFT display. Available fully populated only as far as I am aware.
3. Silicon Chip Explore 64 Backpack with a connector for an ILI 2.4" or 2.8" TFT display. Available as a kit from Silicon Chip.
Alternatives to the 64 pin MM Plus kits might be the Silicon Chip Explore 100 Backpack that has a connector for an SSD1963 4.5", 5" or 7" TFT display. It is available from Grogster with the SMD parts including the PIC32MX chip already soldered.
Hope this helps.
panky
Posted: 07:43am 17 Jul 2018
I have been asked why I DON'T sell the Backpack 2 or the MM+ Backpack. The main reason is that there are three people out there now who currently do, so I did not see the point.
