Can anybody please help me solve a problem? When I use MMEdit (regardless portable or installed version) I collide with problem: pressing the 'Load and Run current code' button (far right) caused error
... ... XMODEM RECEIVE Syntax error ... ... in the Upload Progress window.
I don't know what must I do in order to set the target filename (because the XMODEM RECEIVE command demands the filename, it is obligatory). How to set this filename and remove the syntax error.
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11882
Posted: 05:07pm 28 Aug 2018
What Micromite are your using? You need to set the syntax drop down to the correct part (top right of menu items).
