Local Time 23:44 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : trying to "split" temperature
lew247
Posted: 09:23am 21 Sep 2018
I'm trying to split my indoor and outdoor temperature readings because the decimal point is too big and it makes the display look "not as good as it could"
My two lines of code are
[code]Text 170,155, STR$(val(temp1$),2,1)+"`C" , LB,4, 2,rgb(223,159,54) , RGB(128,128,128) 'Outdoor Temp
Text 170,215, STR$(tempr(11),2,1)+"`C", LB,4, 2, RGB(203,168,24) , RGB(128,128,128) 'Indoor Temp[/code]
I thought it would be
[quote]Text 170,155, LEFT$(val(temp1$),2,1,2))+"`C" , LB,4, 2,rgb(223,159,54) , RGB(128,128,128) ' LEFT DIGITS
Text 170,155, RIGHT$(val(temp1$),2,1,1))+"`C" , LB,4, 2,rgb(223,159,54) , RGB(128,128,128) ' Decimal digit
and
Text 170,215, LEFT$(val(tempr(11),2,1,1))+"`C", LB,4, 2, RGB(203,168,24) , RGB(128,128,128) 'LEFT DIGITS
Text 170,215, RIGHT$(val(tempr(11),2,1,1))+"`C", LB,4, 2, RGB(203,168,24) , RGB(128,128,128) 'DECIMAL digit[/quote]
but no matter what combinations I try I always get an error and it doesn't work
Edited by lew247 2018-09-22
PicFan
Posted: 10:04am 21 Sep 2018
temp$ = "25.75"
print left$(temp$,2)
print right$(temp$,2)
print val(left$(temp$,2))
print val(right$(temp$,2))
run
25
75
25
75
lew247
Posted: 10:19am 21 Sep 2018
  PicFan said   temp$ = "25.75"
run
25
75
25
75
That won't work because I need to limit both temp and tempr (ds1820b) temp to 1 decimal place
PicFan
Posted: 10:29am 21 Sep 2018
temp = 25.75
tmp$ = 30.25
print left$(str$(temp,2,2),2)
print mid$(str$(temp,2,2),4,1)
print left$(tmp$,2)
print mid$(tmp$,4,1)
print "As value:"val(left$(tmp$,2)) * 2
print "DS18B20:"left$(str$(tempr(pin),2,2),2)
run
25
7
30
2
As value: 60
DS18B20: 27
This is not a good solution (neg. numbers etc.), I'll keep trying !!!Edited by PicFan 2018-09-22
lew247
Posted: 11:30am 21 Sep 2018
I still have a problem
While print val(left$(temp1$,2)) works
It doesn't make certain that temp1$ will always have 2 places before the decimal point
If the temp was 13.23° it would print 13 which is correct
but
if the temp was 2.35° it would print 2. which is wrong
I also need it to print the zero if the temp is 0° which this won't do
Also the DS1820B
print mid$(tempr(11),4,1)
WHile this works IF there are 2 numbers before the decimal point
it won't work if there is only 1 or the first digit is zero
Hope that made sense
Posted: 12:07pm 21 Sep 2018
temp10%=CINT(temp*10)
print str$(temp10%\10,2)
print temp10% mod 10
Edited by matherp 2018-09-22
lew247
Posted: 01:52pm 21 Sep 2018
Thanks Peter
I had considered that and yes it would be a lot simpler and easier
but I'd like to keep the decimal place (1 place)
PicFan
Posted: 04:19pm 21 Sep 2018
Try this, i hope, i have you understand ?
Input temp
x$ = str$(temp,2,2)
if (temp < 0) then
vz$="-"
else
vz$="+"
endif
nk$ = mid$(x$,instr(1,x$,".")+1,1) 'xx.7
vk$ = vz$ + str$(abs(fix(temp),1,0)
print vk$" C "nk$
nk$ = mid$(x$,instr(1,x$,".")+1,2) 'xx.75
print vk$" C "nk$
loop
run
? 5.75
+5 C 7
+5 C 75
? -5.75
-5 C 7
-5 C 75
? -0.75
-0 C 7
-0 C 75
