Forum Index : Microcontroller and PC projects : Pi-cromite RSS reader
| MikeO Senior Member Joined: 11/09/2011 Location: AustraliaPosts: 275 |
Here is some code for parsing RSS feeds. I was interested in recovering weather feeds but the code can be used on other feeds such as News items etc. I am using Curl on the Pi Zero to access the URL which seems to work nicely, is non blocking and also leaves the web socket free on the pi-cromite , useful as I can use UDP at the same time without open and closing ports. I have set up a "script" to access a feed at Weather.com.au but other providers like Weatherzone have rss feeds. Their Web page is here Here is the code to date followed by the output from the above mentioned feed. 'Michael Ogden Codenquilts.com.au 'Oct 2018 'Weather.com.au RSS feed recovery ' 'version 0.5 , dim integer a(1000) dim l% dim xp system "curl http://rss.weather.com.au/vic/moe",a() for i=1 to llen(a()) print lgetstr$(a(),i,1); next i l%=0 xp=1 '"script" for Weather.com.au feed print xml$(a(),"title",xp) print xml$(a(),"description",xp) print xml$(a(),"pubDate",xp) print xml$(a(),"ttl",xp) print xml$(a(),"title",xp) print xml$(a(),"<b>",xp) print xml$(a(),"<b>",xp) print xml$(a(),"<b>",xp) print xml$(a(),"<b>",xp) print xml$(a(),"<b>",xp) print xml$(a(),"<b>",xp) print xml$(a(),"<b>",xp) print xml$(a(),"<b>",xp) print xml$(a(),"<p>",xp) print xml$(a(),"<p>",xp) print xml$(a(),"<p>",xp) print:xp=1 print xml$(a(),"<w:current",xp) print xml$(a(),"<w:current",xp) print xml$(a(),"<w:current",xp) print xml$(a(),"<w:forcast",xp) print xml$(a(),"<w:forcast",xp) print xml$(a(),"<w:forcast",xp) end function xml$(xaray%(),xstr$,xp) local xstart,xend,xlen,xreturn local xstr1$ xlen=len(xstr$) ' extract required string if xstr$="<b>" then xlen=len(xstr$) xstart=linstr(xaray%(), xstr$ ,xp) xend=linstr(xaray%(),"<br />",xstart+xlen) xreturn=xend-(xstart+xlen) xp=xend+7 elseif xstr$="<p>" then xlen=len(xstr$) xstart=linstr(xaray%(), xstr$ ,xp) xend=linstr(xaray%(),"</p>",xstart+xlen) xreturn=xend-(xstart+xlen) xp=xend+4 elseif xstr$="<w:current" or xstr$="<w:forcast" then xlen=len(xstr$) xstart=linstr(xaray%(), xstr$ ,xp) xend=linstr(xaray%(),"/>",xstart+xlen) xreturn=xend-(xstart+xlen) xp=xend+2 else xlen=len(xstr$)+2 xstart=linstr(xaray%(),"<" + xstr$ +">",xp) xend=linstr(xaray%(),"</" + xstr$ +">",xstart+xlen) xreturn=xend-(xstart+xlen) xp=xend+xlen+4 end if if xstart>0 then 'print "Total";xreturn if xreturn > 255 then xx=xstart+xlen+256 'get just 255 bytes and exit on error skip xstr1$=lgetstr$(xaray%(),xstart+xlen,255) 'remove any html tags etc xml$=tags$(xstr1$) else on error skip xml$=lgetstr$(xaray%(),xstart+xlen,xreturn) 'remove any html tags etc xml$=tags$(xml$) end if end if exit_xml: 'print xstart;" ";xend;" ";xlen;" ";xreturn;" ";xp end function 'replaceString$(string$, replaceWhat$, replaceWith$) FUNCTION replace$(R$, a$, b$) local integer i,j,c,d d=1 replace$=R$ i = LEN(a$) : j = LEN(b$) do while INSTR(d,replace$, a$) > 0 c = INSTR(d,replace$, a$) replace$ = LEFT$(replace$, c-1) + b$ + MID$(replace$, c+i) d = c+j loop END FUNCTION function tags$(t$) t$=replace$(t$,"<![CDATA[","") 'remove cdata open tag t$=replace$(t$,"<b>","") 'remove <b> open tag t$=replace$(t$,"</b>"," ") 'replace <b> close tag with space t$=replace$(t$,"&","") 'remove & Char t$=replace$(t$,";","") 'remove ; Char t$=replace$(t$,"<br />",chr$(13)) 'replace <br /> tag with LF t$=replace$(t$,"]]>","") 'remove cdata close tag t$=replace$(t$,"<","") 'remove open tag t$=replace$(t$,">","") 'remove close tag tags$=t$ end function Weather.com.au - Moe Weather Current conditions and forecast for Moe, Victoria. Thu, 04 Oct 2018 06:45:00 GMT 15 Moe Current Conditions Temperature: 11.9degC Dew Point: 9.6degC Relative Humidity: 86% Wind Speed: 14.8km/h Wind Gusts: 24.1km/h Wind Direction: E Pressure: 1022.1hPa Rain Since 9AM: 0.0mm Friday: img src="//m6e6i3k5.stackpathcdn.com/images/icons/12.gif" alt="Early Fog Followed by Sun" / Early Fog Followed by Sun. Mild. 7 - 18 Saturday: img src="//m6e6i3k5.stackpathcdn.com/images/icons/2.gif" alt="Mostly Sunny" / Mostly Sunny. Mild. 6 - 22 Sunday: img src="//m6e6i3k5.stackpathcdn.com/images/icons/4.gif" alt="Afternoon Clouds" / Afternoon Clouds. Mild. 8 - 24 temperature="11.9" dewPoint="9.6" humidity="86" windSpeed="14.8" windGusts="24.1" windDirection="E" pressure="1022.1" rain="0.0" temperature="11.9" dewPoint="9.6" humidity="86" windSpeed="14.8" windGusts="24.1" windDirection="E" pressure="1022.1" rain="0.0" Codenquilts |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11881 |
Mike Thanks for posting - another innovative use. I also like the XML parser, this could be a very useful generic routine. |
