Local Time 21:35 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Lcd BackPack + November 2016 Option Help
2001cpx
Posted: 04:49pm 13 Oct 2018
Hi!
Buyed Some Lcd Backpack + at Silicon Store,and i m trying to Find
Option parameter like LCD,Touch,etc.
Does Anyone have this Parameter?
Thanks!
"Color Maximite,(Duinomite-Mega,Mini),CGmmStick,GCmicroboard2b,Micromite + explore 64,100,LCD backpack,Lcd Backpack V2,TFT Backpack,Micromite Extreme,Armmite L,F,H,CMM2"
palcal
Posted: 09:04pm 13 Oct 2018
Do you have the manuals? If not go to Geoff's web site
Phil23
Posted: 09:10pm 13 Oct 2018
It needs the backlight enabled,
PWM 2, 1000, 50
Then
OPTION LCDPANEL ILI934I, L, 2, 23, 29
OPTION TOUCH 1, 3
Cheers.
Chopperp
Posted: 12:11am 14 Oct 2018
@palcal.
Normally you would RTFM first but SC changed a few connections around which can be / is confusing so the setup in the manual is a bit different.
SC, Nov 2016 has the correct set up which is what Phil23 has kindly indicated.
Thanks for the question 2001cpx & the reply Phil23 because I was only thinking the other day as to what the setup was for the MM+64.
Must write it in my programs as a comment so I do have to go looking for the setup again.
ChopperP
2001cpx
Posted: 09:30pm 16 Oct 2018
Thanks Phil23!
Work Ok,Nice PCB.
i made a bypass for backlight,i don t have a small fet in stock,screen is ok.
Thanks Again!!
Chopperp
Posted: 11:18pm 16 Oct 2018
My SC + Explore 64 had the FETS as part of the kit & should have been fitted when you built your kit. (Then again, I could be wrong)
Using PWM 2, 1000, 50 will bring the backlight on. No extra wiring required
ChopperP
2001cpx
Posted: 11:25pm 16 Oct 2018
Hi Chopperp,
I Buyed Only The PCB,The Rest of Components,in Stock ,But this Fet no.
(Digikey have this,but not in sot-23) ,i think
Chopperp
Posted: 11:48pm 16 Oct 2018
Hi 2001cpx
OK, I was wondering if that may have been the case.
What did you actually do to bring the backlight on? A series resistor?
Brian
ChopperP
Azure
Posted: 01:18am 17 Oct 2018
The SC Explore 64+BP has an option to load either PWM drive or Trimpot resistor divider.
Chopperp
Posted: 06:52am 17 Oct 2018
@Azure
In the RH column on page 65 it says that VR1 has been deleted from this unit & Mosfets used instead to control the TFT backlighting.
Easy enough to use an external pot instead of the Mosfets though if you don't want the lighting software controlled.
ChopperP
Azure
Posted: 03:47am 18 Oct 2018
  Chopperp said  In the RH column on page 65 it says that VR1 has been deleted from this unit & Mosfets used instead to control the TFT backlighting.
You are quite right. I was thinking of the SC MM V2 Backpack, my mistake. I just double checked both articles to make sure I didn't also recall that incorrectly.
Chopperp
Posted: 07:06am 18 Oct 2018
I had to triple check that I had my facts straight before posting.
We are spoilt for choices with the 'Mites etc. Started going some of the SC 'Mite articles from around that period. Interesting reading. A lot to learn & so much to forget!!!
ChopperP
Azure
Posted: 02:36am 19 Oct 2018
I have been getting all the PCB's and parts to build most of the SC MM based projects. Problem for me at the moment is a lot of interruptions and other work that have priority which I have to address before I can dedicate some decent time into MM things.
New Accurate Freq Ref project using MM Backpack in this months issue will be added when it's PCB becomes available.
Then there are so many great things TBS members have built that I want to look into more on TBS.
2001cpx
Posted: 05:55pm 19 Oct 2018
@Chopperp
Backlight,direct 3.3v on pin Led.
surely better contrast with resistor.
Chopperp
Posted: 10:53am 20 Oct 2018
@2001cpx
OK thanks. Just tried mine at 100%. Not that much different from 50%. Still playing. Readable at 10% as well.
ChopperP
