Local Time 17:33 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite trig functions cached?
factotum
Posted: 03:03pm 26 Oct 2018
I've been timing some Micromite Basic functions of mine that are very heavy on calling sin, cos, tan etc. I am surprised how fast they are. One function that calls a lot of trig functions only takes 42 ms at 10 MHz clock.
Although I have made some effort to call them with a variety of different arguments within the timing loop, I just wondered if the trig library might contain some caching mechanism that remembers recently-requested argument values and returns the result quickly, rather than re-cacluating it from scratch.
Anyone know?Edited by factotum 2018-10-28
Paul_L
Posted: 04:20pm 26 Oct 2018
It's very simple to test it.
t1=timer
for j=1 to 100
for i=0.1 to 1.5 step 0.1
A=sin(i) '1500 calls to sin with different values
next i
next j
t2=timer-t1:print t2
t3=timer
for j=1 to 1500
A=sin(1) '1500 calls to sin with the same value
next j
t4=timer-t3:print t4
Paul in NY
Posted: 07:04pm 26 Oct 2018
That might fail as a test. E.g. if some values take longer to calculate than others.
Is reading the source code not an option?
I think it's more a case of the CPU being fast :)
JohnEdited by JohnS 2018-10-28
CaptainBoing
Posted: 08:42pm 26 Oct 2018
  factotum said   I've been timing some Micromite Basic functions of mine that are very heavy on calling sin, cos, tan etc. I am surprised how fast they are. One function that calls a lot of trig functions only takes 42 ms at 10 MHz clock.
Although I have made some effort to call them with a variety of different arguments within the timing loop, I just wondered if the trig library might contain some caching mechanism that remembers recently-requested argument values and returns the result quickly, rather than re-calculating it from scratch.
I doubt it - that is a very broad broom with no real reason to expect you'd be wanting the same answer.
I would imagine the transcendental functions are a product of the C compiler (and it's libraries) which most likely uses Polynomial functions to calculate the values. The time to cache and then search that cache is just too hit n miss, and wasted effort if a suitable match isn't found... just get down to the business of calculating the value.
Polynomials of short sequences are very fast - I coded several in my early 20's to convert frequencies from a sonde receiver into real-life pressure, temperature & humidity values for PILOT/TEMP messages for the met office. Even on a 4MHz Z80 running interpreted basic they were over in the twinkle of an eye.
Edited by CaptainBoing 2018-10-28
Posted: 10:08pm 26 Oct 2018
No, there is no caching.
In MMBasic SIN(), TAN(), etc are just wrappers around floating point library functions provided by Microchip with their C compilers for the PIC32 family of chips. Microchip boast that these functions are carefully tuned for speed and they are fast.
Another factor is the PIC32 chip with its MIPS processor core - it is very fast. In the 90's a number of million dollar minicomputers (Tandem, Pyramid) were built around the MIPS processor and now you can get the same technology in a $10 chip. The rate of change is amazing.
GeoffEdited by Geoffg 2018-10-28
factotum
Posted: 03:11pm 30 Nov 2018
Thanks for the above responses. Sorry I didn't get back sooner.
