Local Time 19:28 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Ipad/IOS and MMEdit?
lew247
Posted: 07:57am 17 Nov 2018
I've got myself one of the new Ipad Pro's and I'm seriously considering binning Windows altogether as compared to my Windows with an i7 cpu it's blindingly fast
It also has the advantage of having a USB-C port on the bottom so it can connect to other devices
I love MMEdit and I've been using it since I started with MM and I know there's also Micromite Console
I've already found Putty Alternatives
Is there anything similar to MMEdit for IOS?
sagt3k
Posted: 09:23pm 18 Nov 2018
Hi lew247
Very interesting topic
Micromite Console has been implemented with Delphi Starter 10.2.x only for Win32/64.
Personally at work I use Delphi XE7 with Firemonkey technology.
In this way it is possible to write the code once and compile on different systems.
Personally I have developed a simulation system with the same code on three different systems: Windows/32/64, MACOSx and Android but Delphi XE7 has several problems and I have to abandon it to buy a new version of Delphi 10.3x by 2019 Q2/Q3.
It is possible to think "Micromite Console" on different systems but not in the short-term.
Antonio
