Local Time 18:33 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Monitoring battery voltage
PhilTilson
Posted: 05:04pm 28 Nov 2018
Can anyone point me to a simple method of monitoring the battery voltage of a project?
I took the obvious route of reading the 5V supply of a Micromite Plus (via potential divider) but, of course, that suffers from the problem that, as the battery voltage falls below a certain point, the reference voltage on the chip falls as well, so the measured voltage is inaccurate, and you never get to an end point!
The project is powered from a single 18650 Li cell, usually kept topped up from a 5.5V external power supply via a charge controller. I just want a way to tell when the Li cell has dropped below its minimum voltage so that I can then power down the unit.
I know I could use a brownout function, but that wouldn't give me an indication of how far things had got.
Or am I missing something obvious? (probably )
Posted: 05:08pm 28 Nov 2018
Page 49 of Getting Started With the Micromite has an example of one way to do it.
PhilTilson
Posted: 10:45pm 28 Nov 2018
Thanks Geoff, that's really helpful!
Phil
