Local Time 18:23 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Printing binary values to serial consol
factotum
Posted: 03:14pm 30 Nov 2018
I'm having trouble with limited bandwidth on a LoRa telemetry link that takes data PRINTed to the MM console. One thought was to recode the data in binary thus reducing its size, but I can't see any way of printing binary bytes to the console. Just wondered if there was.
CaptainBoing
Posted: 03:36pm 30 Nov 2018
have a look at the BIN$() function
it takes a numerical argument and converts it to a stream of 1's & 0's
so
>print 10
10
>print bin$(10,8)
00001010
factotum
Posted: 03:42pm 30 Nov 2018
Thanks, but that's kind of the opposite of what I want to do. But now you've made me think that probably what I need is to use PRINT CHR$(binary byte)
Posted: 03:53pm 30 Nov 2018
Yes, use CHR$
CaptainBoing
Posted: 04:02pm 30 Nov 2018
ok, to take a binary string of 1s & 0s and print the decimal version you have to process it as a string... like so
> a$="00001111"
> print Val("&b"+a$)
15
what this does is use the Val function to extract a decimal value from a string, but you change the radix of the string by prefixing with "&b" which means binary.
other prefixes are &h - Hexadecimal, and &o - Octal
DOH! I read your post again ... yes the value you hold in a variable 0-255 in value - just print the CHR$() and you'll get your character.Edited by CaptainBoing 2018-12-02
factotum
Posted: 05:07pm 30 Nov 2018
Thanks all.
