Local Time 17:33 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Invalid Option errors
Dabbler
Posted: 04:33am 02 Dec 2018
Hi
My Micromite backpack setup has just started to not recognise some basic options.
When I try to download a program I know works, that starts with
OPTION AUTORUN ON. It comes back with
Error: invalid option
if I remove this line, the same error is returned for OPTION EXPLICIT and OPTION DEFAULT INTEGER.
If I remove all of these the program will run but not autorun etc.
What is happening?
Posted: 06:30am 02 Dec 2018
Good question.
I can only recommend re flashing the firmware as something seems to have seriously gone wrong.
Posted: 09:28pm 02 Dec 2018
Agreed. That is very strange. So to be sure you are working from a non-corrupted MMBASIC, I would also reflash. If it still does it after that, all I could say then was perhaps a damaged chip, so you'd need to mark that one as suspect(or bin it), and switch to another chip.
