Forum Index : Microcontroller and PC projects : PC Audio Compressor/Limiter...
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10042 |
I am looking for something along the lines of Volume Logic which I used to use, but now does not seem to be available. Do any members have any suggestions? Perfectly happy to pay for it, if it works. Smoke makes things work. When the smoke gets out, it stops! |
| aladdin4d Newbie Joined: 26/01/2019 Location: United StatesPosts: 3 |
Breakaway Audio Enhancer is the direct successor to Volume Logic. Unlike Volume Logic it's Windows only. For a Mac there's something called Audio Hijack. It's really for capturing any audio but it can be setup to route your audio through an effects chain similar to Volume Logic. I don't know if it's still possible but at one time you could even get it to use the 32 bit Volume Logic as a plugin and apply it to the output of 64 bit iTunes |
Hello and welcome to the forums. ![]() Thank you for your post. This sounds(pun?) just like what I need. Thank you. At US$30, it is also very affordable too. Thanks again. ![]() Smoke makes things work. When the smoke gets out, it stops! |
