Local Time 13:32 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Stripping leading space from PRINT?
BobC
Posted: 04:08pm 07 Feb 2019
I have a plotting app (Stamp Plot) that plots serial data sent from a micro ( MM in this case ). It wants a string consisting of numeric values ( numbers ) terminated with a 0x0d CR.
I'm not plotting data because I believe it does not like the leading space sent in a print statement. Error message I'm getting is Bad Data ASCII value <13 or >127.
I suspect it is because of the leading space.
Any way to strip this space out and print only numeric values? I tried ABS but still got the leading space.
Any ideas welcome!
Thanks!
Bob
GA USA
twofingers
Posted: 04:46pm 07 Feb 2019
  BobC said   I'm not plotting data because I believe it does not like the leading space sent in a print statement. Error message I'm getting is Bad Data ASCII value <13 or >127. I suspect it is because of the leading space.
I doubt that! Space is ASCII 32.
For the unwanted leading spaces you can use this code
'Remove leading Spaces from string
Function LTrim$(X$)
Local I,Z$ Length Len(X$)
'Make copy of caller's string so that we don't damage it
Z$=X$
For I=1 To Len(Z$)
'Find first NON-Space character
If Mid$(Z$,I,1)<>" " Then
Z$=Mid$(Z$,I)
Exit For
EndIf
Next I
LTrim$=Z$
End Function
' Remove trailing Spaces from string
' Peters rTrim, modified by twofingers
Function RTrim$(X$)
Local I
For I=Len(X$) To 1 Step -1
If Mid$(X$,I,1)<>" " Then
Exit For ' be careful with Exit For
EndIf
Next I
RTrim$=Mid$(X$,1,I)
End Function
'Remove spaces from LHS and RHS of string
Function Trim$(X$)
Local Y$ length Len(X$)
'MMBasic doesn't like Trim$=RTrim$(LTrim$(X$))
Y$=LTrim$(X$)
Trim$=RTrim$(Y$)
End Function
and for the MM2 as CFunction this
https://www.thebackshed.com/forum/forum_posts.asp?TID=9738
Michael
Edited by twofingers 2019-02-09
The lone and ...
Posted: 07:08pm 07 Feb 2019
Show us the part of code doing the PRINT :)
Maybe you're using something like
PRINT n
when what you want is more like
PRINT STR$(n)+CHR$(13);
Paul_L
Posted: 06:33am 09 Feb 2019
The print routine is finding an unprintable character in the string you are handing it. (ASCII value <13 or >127). Print out the ASCII value of each character in the target string, PR$, like this.
for i=1 to len(PR$)
print asc( mid$(PR$,i,1) ),
next i
Inspect the results looking for something <13 or >127.
Paul in NY
MicroBlocks
Posted: 09:00pm 09 Feb 2019
Check if the print statement is outputting a 0x0D0x0A pair (carriage return & linefeed) which is the standard with dos/windows.
A 0x0A (dec 10) is lower then the 0x0D (dec 13) of a carriage return.
If the output is parsed with a 0x0D on the end then the next character would be the 0x0A giving you a wrong first character.
Example two numbers 567 and 568
5670x0D0x0A5680x0D0x0A
The first parsed value delimited by a 0x0D wil be 567, the second vanlue will be 0x0A568 which will have an invalid first character.
Edited by MicroBlocks 2019-02-11
