Forum Index : Microcontroller and PC projects : Micromite CPU Exception Error
| subalib Newbie Joined: 07/02/2019 Location: AustraliaPosts: 11 |
I have been experimenting with CPU speeds on the Micromite Plus 100. Specifically at the start of a program. I inadvertently set CPU 120 at the start of a program and now all I get is a string of CPU Exception errors before it displays CPU restarted. Unfortunately it seems to be locked up at this point and does not display the command prompt to allow me to redit the program. Any help would be appreciated. Thanks |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11881 |
Micromite manual - page 16 for how to reset |
Check out the section "Resetting MMBasic" on page 16 of the Micromite User Manual which can be downloaded from here: http://geoffg.net/micromite.html (scroll to the bottom of the page). Geoff Graham - http://geoffg.net |
Thank you. All sorted. I must have missed that page while reading about the Micromite. |
