Local Time 12:35 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Just ordered: Armmite L4 will support
Posted: 02:09pm 22 Feb 2019
B-L475E-IOT01A1
STM32 IOT DISCOVERY NODE
  Quote  Ultra-low-power STM32L4 Series MCUs based on Arm® Cortex®-M4 core with 1 Mbyte of Flash memory and 128 Kbytes of SRAM, in LQFP100 package
64-Mbit Quad-SPI (Macronix) Flash memory
Bluetooth® V4.1 module (SPBTLE-RF)
Sub-GHz (868 MHz or 915 MHz) low-power-programmable RF module (SPSGRF-868 or SPSGRF-915)
802.11 b/g/n compliant Wi-Fi® module from Inventek Systems (ISM43362-M3G-L44)
Dynamic NFC tag based on M24SR with its printed NFC antenna
2 digital omnidirectional microphones (MP34DT01)
Capacitive digital sensor for relative humidity and temperature (HTS221)
High-performance 3-axis magnetometer (LIS3MDL)
3D accelerometer and 3D gyroscope (LSM6DSL)
260-1260 hPa absolute digital output barometer (LPS22HB)
Time-of-Flight and gesture-detection sensor (VL53L0X)
2 push-buttons (user and reset)
USB OTG FS with Micro-AB connector
Expansion connectors:
Arduino™ Uno V3
PMOD
Flexible power-supply options:
ST LINK USB VBUS or external sources
On-board ST-LINK/V2-1 debugger/programmer with USB re-enumeration capability: mass storage, Virtual COM port and debug port
Not as cheap as a Nucleo - but lots of possibilities (WIFI )
Edited by matherp 2019-02-24
OA47
Posted: 08:08pm 22 Feb 2019
A lot of possibilities come to mind. $88 from Element14 here in AUS.
OA47
