Local Time 09:49 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM.Basic suggestion
palcal
Posted: 09:05pm 08 Apr 2019
From what I can find in the data sheet the DS3231 does not have any useable memory so the RTC SETREG and RTC GETREG commands can only be used on the DS3232 which costs about AU$22.
The DS3231 module has the AT24V32 (32kBit EEPROM) on board (at least all the ones I have do). So a question for Geoff, would it be possible to incorporate twofingers code, or enough of it to save variables, into MM.Basic, it would be much more useful than RTC SETREG and RTC GETREG.
Posted: 08:16am 09 Apr 2019
The problem is that there are so many EEPROM chips (and other chips) that it is impossible to support them all within MMBasic. So I only put in support for the really popular functions like measuring temperature. The proper way to support this type of chip is with a CFunction but, from what I can remember, this has not been written yet for the AT24V32.
But, what is wrong with twofingers' code? You could load it into the library and it would then be part of your MMBasic. Easy.
palcal
Posted: 08:35am 09 Apr 2019
Ah yes the Library, forgot about that.
Thanks Geoff.
