Local Time 08:00 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : COM question
Tinine
Posted: 08:38pm 24 May 2019
Hey guys,
I need to handle this in MMBASIC.
1 start bit and 1 stop bit?
There is a QB example and it simply shows [BAUD],N,8,1
"The communication protocol uses 8 data bits, 1 start bit, 1 stop bit and no parity."
The above quote is from the documentation.
Cheers!
seco61
Posted: 01:41am 25 May 2019
Hi.
This is the default that the MMBASIC COM ports will use - so you do not have to do anything special to get this.
Example for 9600 baud:
OPEN "COM1:9600" AS #1
You can add extra options if you want to increase the default RX buffer size and/or use an interrupt (which I thoroughly recommend).
Gerard (vk3cg/vk3grs)
Turbo46
Posted: 01:48am 25 May 2019
Hi Tinine,
  Quote  8 data bits, 1 start bit, 1 stop bit and no parity
That is pretty much the default for serial communications. See the Manual in the "Serial Communications" section.
The Manual says:
  Quote  OPEN comspec$ AS #fnbr
‘fnbr’ is the file number to be used. It must be in the range of 1 to 10. The # is optional.
‘comspec$’ is the communication specification and is a string (it can be a string variable) specifying the serial port to be opened and optional parameters. The default is 9600 baud, 8 data bits, no parity and one stop bit.
It has the form "COMn: baud, buf, int, intlevel, DE, 9BIT, INV, OC, S2"
Simply:
Open "Com1:9600" as #1
will do it where 9600 is the baud rate (see the manual for the available baud rates).
Bill
Edit: Sorry Gerard I was typing at the same time.Edited by Turbo46 2019-05-26
seco61
Posted: 02:14am 25 May 2019
Hi Bill.
What can I say - great minds and all that...
