Local Time 07:03 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite serial issues
shoots
Posted: 02:55pm 01 Jun 2019
I am working with a micromite with an LCD backpack.
Can anyone suggest where I am going wrong here please. I am trying to send a stream of data to an external device. One of streams I want to send out is, with ascii character and hex value in brackets) :
C (0x43) U (0x55) 0 (0x30) 7 (0x37) 23 (0x17)
Checking with my logic probe shows what is actually going out is:
6 (0x36) 7 (0x37) 8 (0x38) 5 (0x35) 4 (0x35) 8 (0x38) 5 (0x35) 5 (0x35) 2 (0x32) 3 (0x33)
The receiver is not able to handle this as it expects the former stream of 5 bytes of data not the 10 bytes being sent. It is like each byte is being split into two.
My code related to serial tx:
dim integer aByte(9)=(&H52,&H30,&H30,&H31,&H42,&H35,&H38,&H44,&H43,&H17) '7000rpm
dim integer uartselect(4)=(&H43,&H55,&H30,&H37,&H17)
dim integer increment
open "com1: 115200, 512" as #5
for increment=0 to 4
print #5; str$(uartselect(increment));
next
Thank you for any suggestions.
Peter
twofingers
Posted: 04:03pm 01 Jun 2019
Hi Peter
hmm, this code gives me
Dim integer uartselect(4)=(&H43,&H55,&H30,&H37,&H17)
'open "com1: 115200, 512" as #5
Print "Str$"
For increment=0 To 4
Print Str$(uartselect(increment)),increment
Next
Print
Print "Chr$"
Print Chr$(uartselect(increment)),increment
Next
Print
Print "Hex$"
Print Hex$(uartselect(increment)),increment
Next
Print
End
this output:
Str$
67 0
85 1
48 2
55 3
23 4
Chr$
C 0
U 1
0 2
7 3
4
Hex$
43 0
55 1
30 2
37 3
17 4
edit:
Maybe, if you want to send bytes (uartselect()) then you should replace
Print #5; Str$(uartselect(increment))
with
Print #5; Chr$(uartselect(increment))
  Quote  Checking with my logic probe shows what is actually going out is:
That's exactly what you are sending with
Print #5; Str$(uartselect(increment)).
67, 85, 48, 55, 23.
MichaelEdited by twofingers 2019-06-03
The lone and ...
shoots
Posted: 11:53pm 01 Jun 2019
Hi Michael,
Thank you for that. Spot on! Changed to Chr$ and it worked immediately. A careful reread of the manual and I understand the different- Chr$ returns a ONE character string.
Cheers,
Peter
