Forum Index : Microcontroller and PC projects : Micromite GUI frame and radio buttons iss
| shoots Newbie Joined: 31/07/2011 Location: AustraliaPosts: 32 |
Hi, Micromite plus 100 with touch screen/LCDPANEL SSD1963_5A,L I am having issues setting up two sets of radio buttons, each with its own frame. The first set of buttons- 2 &3 are within frame 1. The second set - 7 & 8 are within frame 6. On their own each works ok but with both frames and sets of buttons configured the upper frame only works ok except when a button in the lower frame is touched the upper radio button goes off. The lower frame radio buttons just go on and when touched they do not go off (you can end up with both on) and are not affected by the upper buttons being touched. I did comment out the top frame and buttons and set up a another frame and buttons below frame 6 and had the same issue- the top frame etc partly worked. I have an interrupt that is triggered when a button is touched and this works ok for all buttons so I know they are registering. It is just that the interaction of the buttons is not staying within their respective frames! Is it only possible to have one frame and set of buttons per page? The spinbox and other items wok ok. Below is the code related to setting up the frame and buttons: GUI Frame #1, "CONTROL METHOD", 15, 15, 600, 100', RGB(200,20,255) GUI Radio #2, "PRESSURE", 60, 65, 15', RED GUI Radio #3, "SPEED", 400, 65, 15', RED CtrlVal(3) = 1 GUI SWITCH #4, "Start 20", 50, 400, 200, 80,RGB(white), RGB(brown) CtrlVal(4) =1 GUI SPINBOX #5, 50, 350, 200, 50,RGB(white),RGB(red),10, 10, 100', RGB(white), RGB(brown)', RGB(200,20,255), RGB(100,125,155) CtrlVal(5) =100 'start pressure set up GUI Frame #6, "Pressure cm H20", 30, 200, 700, 100', RGB(200,20,255) GUI Radio #7, "20", 100, 250, 15 GUI Radio #8, "40", 400, 250, 15 Any advice would be much appreciated. Thank you. Regards, Peter |
This should not be happening. I have people staying with me for a few days and when they leave I can have a look at it. Has anyone else seen this sort of thing? Geoff Graham - http://geoffg.net |
goc30![]() Guru Joined: 12/04/2017 Location: FrancePosts: 435 |
hi shoots it seems that framebox work only when they are in left/right position and not in up/down position I put here your code with changes (frame position do/loop and interrupt functions) cls GUI Interrupt TouchDown, TouchUp GUI SPINBOX #5, 50, 350, 200, 50,RGB(white),RGB(red),10, 10, 100 CtrlVal(5) =50 GUI SWITCH #4, "Start 20", 300, 350, 200, 80,RGB(white), RGB(brown) CtrlVal(4) =1 GUI Frame #1, "CONTROL METHOD", 15, 15, 200, 300', RGB(200,20,255) GUI Radio #2, "PRESSURE", 50, 100, 15', RED GUI Radio #3, "SPEED", 50,200 CtrlVal(3) = 1 'start pressure set up GUI Frame #6, "Pressure cm H20", 250, 15, 200, 300', RGB(200,20,255) GUI Radio #7, "20", 300,100, 15 GUI Radio #8, "40", 300, 200 do loop Sub TouchDown Select Case Touch(REF) ' find out the control touched Case 4 ' spin print "start" Case 5 print CtrlVal(5) Case 2 print "pressure" Case 3 print "speed" Case 7 print "20" Case 8 print "40" End Select End Sub ' interrupt routine when the touch is removed Sub TouchUp Select Case Touch(LASTREF) Case 5 print CtrlVal(5) End Select End Sub |
Hi goc30, I would never have guessed that! Thank you- indeed it resolves the issue and a change in layout is not a problem. One other question- your program results in a beep from the piezo only when the radio button itself is pressed while mine beeps when any part of the screen is touched- even where there is no button. What is the secret to this? Thank you. Regards, Peter |
you have an beep each time you touch screen if you put "click_pin" on "option touch" OPTION TOUCHT_CS pin, T_IRQ pin [, click pin] 'click pin' specifies an optional I/O pin that will be driven briefly high when a screen control is touched. This can be used to drive a small Piezo buzzer. but in your code you can use "BEEP" function on interrupt subroutine exemple: Sub TouchDown Select Case Touch(REF) Case pb_test ' the alarm test button CtrlVal(led_alarm) = 1 GUI beep 250 End Select End Sub |
Thanks goc. I will add that one to my list of bugs to be fixed. Geoff Graham - http://geoffg.net |
Thanks Goc, I'll give that a go. Adds another level of sophistication to the project! |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10042 |
Well done, goc30, for helping to define that bug so it can be squished. Smoke makes things work. When the smoke gets out, it stops! |
Hi Guys, Thank you for the suggestions. I have reconfigured with OPTION TOUCH 1, 40 and now I do not have the beep every time the screen is touched, but the GUI beep xxx command does not work and I can see no way to make it so without the OPTION TOUCH [,click pin] set to the pin number-39. this is the message returned from the serial port when it encounters the command GUI beep 20: OPTION LCDPANEL SSD1963_5A, LANDSCAPE OPTION TOUCH 1, 40 GUI CALIBRATE 1, 125, 3870, 2049, -1296 141 [342] GUI beep 20 Error: Click option not set It did not matter if I setup pin 39 as a digital output or not with SETPIN 39,DOUT Am I missing something in the configuration? Regards, Peter |
hi shoot for click you must declare pin connected with buzzer, AND pin used for interrupt (not same) AND chip Select pin OPTION TOUCH T_CS pin, T_IRQ pin [, click pin] your option touch is not good OPTION TOUCH 1,40 is bad you must declare OPTION TOUCH chip select pi, interrupt pin, buzzer pin OPTION TOUCH 1,40,39 if 40 is interrupt pin and 39 is buzzer pin |
Thank you Groc, I think I see where I went wrong.... I had a Gui beep command at the beginning of the interrupt routine. This is why I was getting a beep for any and every touch. When I get home from work I'll reinstate the option touch click parameter and remove the offending gui beep command. Thanks for the patient help!! Regards Peter |
I gave it a try this evening and it worked a treat. It was the stray GUI beep I had put at the beginning of the interrupt. Thank you for the help- and without your first bit of code goc I would not have realised what was possible! And thank you to Geoff- your creation of the Micromite and MM basic has opened up so much enjoyment, learning and satisfaction in electronics and programming for so many. And in such a affordable package. It would be interesting to know how many MMs have been put together and what sort of projects have been undertaken. Cheers, Peter |
