viscomjim Guru Joined: 08/01/2014 Location: United StatesPosts: 925
Posted: 12:25pm 12 Jun 2019
Is there any way to reset the uMite (28pin) with a command in a program other that to use the watchdog timer, for example if Xx = 30 the RESET. This would restart the uMite and run the program again via option autorun on.
Thanks for any ideas...
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11881
Posted: 12:26pm 12 Jun 2019
CPU RESTART
Posted: 01:13pm 12 Jun 2019
Thank you kind sir!!!
Posted: 03:30pm 12 Jun 2019
Can using cpu restart be in any way detrimental to the micromite?
Posted: 09:41pm 12 Jun 2019
No, it just executes a jump command to the start of the normal power-on initialisation sequence.
