Local Time 05:03 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : H7 + OV7670
Tinine
Posted: 06:18am 26 Jun 2019
I am very interested in this. Regarding the Movement() function, does this only compare subsequent camera frames or can a frame be compared with a previously stored image? If so, at what frequency can this comparison be done? IOW, retrieving a stored image and comparing it with the current camera image.
KeepIS
Posted: 05:34am 30 Jun 2019
I remembered your post just now and don't know if you found your answer but I think this is what you want?
I was going through the MM.INFO$ commands in the manual and found the following:
MOVEMENT(sensitivity)
[code]
This function combines capturing a new image from an OV7670 camera with a
comparison with the currently displayed image. It returns the number of
pixels that are different between the images.
The sensitivity parameter controls whether or not a pixel is considered
to be different.
The algorithm works by converting each image to a 6-bit greyscale image.
The sensitivity is then the difference between the pixels that will be
counted as a change.
The top 20 and bottom 20 rows are ignored in the comparison.
This allows the user to use these for other display purposes without
artificially triggering the movement detection.
[/code]
NANO:Inverter V 8.4ksLinux AvrDude GUI script V4.1
