Local Time 05:04 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Non volatile storage (for frequent use)..
Tinine
Posted: 11:34am 03 Jul 2019
I am aware of the battery backed memory, available with some RTC modules but Geoff recommended some other device, somewhere in the MM documentation....can't seem to locate the info, now...any clues? I believe that it was EEPROM but can't be sure.
disco4now
Posted: 11:44am 03 Jul 2019
have you seen this
F4 H7FotSF4xGT
Tinine
Posted: 12:17pm 03 Jul 2019
Very interesting...Thanks.
I was also considering one of these to try on my E100
Posted: 12:49pm 03 Jul 2019
I believe that this is what you are looking for:
2019-07-03_224917_UNIO.zip
Tinine
Posted: 02:41pm 03 Jul 2019
Ah, that's the one, thanks Geoff.
Brings me to another question: There's more mention of "clean power":
I just threw some 8-bit MC devices on Perma-Proto board (nice stuff) and they just would not start. I had neglected to fit bypass caps between VCC & GND (0.1uf). Fitted the caps and the devices sprang to life. Wouldn't it be prudent to do the same with this device?
Posted: 09:56pm 03 Jul 2019
Yes, bypass caps are important. When I was developing the CFunction I had a lot of trouble getting it to work reliably and clean power fixed the problem.
BTW that zip file is in the Embedded C Modules folder of the Micromite firmware distribution zip file. There is a lot of good stuff in there but it is often overlooked.
viscomjim
Posted: 11:48am 04 Jul 2019
That's true. My favorites are the rx and tx cfunctions. They work great!!!!
