Forum Index : Microcontroller and PC projects : Embedding Configuration Options
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2265 |
Is this still supported or has it been dropped? I can't seem to find any info in the manual and OPTION SAVE is not listed in the Manual I have. A quick look at the option list on the ArmH7 and it doesn't display GUI Calibrate values in any case. I remember When Geoff introduced this in Micromite firmware V5.04.10 (Beta 8) using OPTION SAVE, I tried it out but just kept getting error messages, I was in a hurry at the time and I never got back to it. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Yes, it is definitely there in all MM2 and MM+ versions since Ver 5.05.01. Page 59 and 69 of the Micromite User Manual at http://geoffg.net/micromite.html#Downloads. It works well, I use it a lot when testing. I'm not sure if it made it into the ArmH7 version (a question for Peter). Geoff Geoff Graham - http://geoffg.net |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11880 |
This isn't implemented on any of the Armmite versions. However, because all the STM32 chips have a built-in bootloader is is very easy to save a firmware image once the options have been programmed and use this to program new chips using STM32CubeProgrammer |
Thanks Geoff and Peter, I though I had the latest Micromite manual but downloading the latest version revealed the option ![]() For the ArmH7 I was hoping the end user would not need to use STM32CubeProgrammer if a board needed to be changed/upgraded, still no big deal in any case as the options are pretty easy to cut and paste. Thanks again for the concise information. Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
