Local Time 04:06 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Versions, PRINT @ -- CURSOR
Paul_L
Posted: 02:14am 09 Jul 2019
I'm confused about the commands for locating a print result on the display.
In the 4.5 manual I see {PRINT @(x,y,m) expression}.
In the 5.05 manual I see {CURSOR x,y} and {PRINT expression}, but {PRINT @} is missing.
Which or these will survive in future versions? Which will work in DOS, which in the F4?
(I hope PRINT @(x,y,m) is the survivor.)
Paul in NY.
OA47
Posted: 05:10am 09 Jul 2019
Paul are you confusing the Maximite graphics in ver 4.5 with the Micromite Plus graphics. I so they are not related.
0A47
Posted: 06:57am 09 Jul 2019
- The Maximite has PRINT @(x,y,m)
- The DOS/Windows MMBasic has CURSOR x,y
- The Micromite has the TEXT command.
They are different platforms with different requirements.
I am working on an update to the Maximite (a BIG job) to bring the BASIC interpreter up to V5.05 but I hope to keep all the peripheral commands (like @(x,y,m)) unchanged so that feature should still be in the new version. I don't have plans to put @(x,y,m) in the DOS/Windows version.Edited by Geoffg 2019-07-10
Paul_L
Posted: 08:19am 09 Jul 2019
Hi Geoff,
Which one will work in the F4?
Paul in NY.
Posted: 09:03am 09 Jul 2019
  Quote  Which one will work in the F4?
Do you mean the Armmite F4? If so that is a effectively a Micromite and uses the TEXT command. This has nothing to do with the work Geoff is doing on the Maximite. I maintain the Armmite code and keep it largely in-line with Geoff's Micromite versionsEdited by matherp 2019-07-10
