Local Time 02:58 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Is this a trap waiting to happen?
Malibu
Posted: 11:08pm 06 Aug 2019
G'day All
I'm fiddling with code optimizing and generally trying to improve the 'flow' of my code. Just to push it a little further, I'm trying arrays of GUI controls, with local declarations for the GUI elements...
Here's what I've come up with -
sub GuiSetup
gui setup 1 'Show the main options frame
local OptionsFrame=16
Font 4
gui frame OptionsFrame," Change Time/Date ",1,50,790,200,rgb(Cyan)
gui setup 2 'Show the Time/Date radio buttons
local X=50, Y=100 'Declare the initial X,Y coordinates
Local TimeRadioID(5)=(10,11,12,13,14,15) 'Setup the Array identifiers
Local String TimeRadioStr$(5) Length 6=("Hour","Minute","Second","Day","Month","Year") 'Assign the names to the buttons
font 4
for i = 0 to 5 'Loop through the array
gui radio TimeRadioID(i), TimeRadioStr$(i), X,Y,15,RGB(cyan) 'Add the radio buttons
X=X+180 'Next X position
If i=2 then 'First 3 radios are done
X=50 'Reset the X position
Y=150 'New Y position
end if 'Reset complete
next i 'Do the next item in the array
ctrlval(TimeRadioID(0))=1
gui setup 3'Show the Increase/Decrease arrows
Local IncreaseButton=17, DecreaseButton=18
Font 8 'Change to the ARROW font
gui button IncreaseButton, " ", 700,75,66,66,RGB(green)'Space is the UP arrow
gui button DecreaseButton, "!", 700,160,66,66,RGB(green)'! is the DOWN arrow
end sub
(Note: This is only the GUI SETUP in my coding, so it won't actually do anything if you cut and paste to try it out)
This was much easier and painless than I thought it would be (testament to MM Basic!) but I'm now wondering if putting LOCAL declarations for the GUI elements in the GUI SETUP is somehow going to trip me over further down the track?
So far, I haven't had any problems!
Any thoughts would be appreciated
panky
Posted: 01:43am 07 Aug 2019
@malabu
The problem with using LOCAL for GUI element names inside the sub is that the declaration is only available inside the sub.
In some GUI cases this would not be a problem however, if you needed to refer to that GUI element using CTRLVAL to assign a different value elsewhere in your program, the GUI name would not be available outside the sub and would throw an error.
INMHO, it is better practice to declare the GUI element names as CONST at the start of your program along with other DIM statements etc. then they are globally available.
panky
Malibu
Posted: 03:22am 07 Aug 2019
  Quote  The problem with using LOCAL for GUI element names inside the sub is that the declaration is only available inside the sub.
Thanks Panky... you're exactly right because that's what happened as I found out a couple of hours after my initial post.
I tried to do something to a GUI element (can't remember now, I think a GUI Hide) and I ran into a 'Not Declared' error.
I guess that's why I had the niggling doubt over the merit of what I'd done.
Thanks for your input!
Posted: 06:49am 07 Aug 2019
  panky said  INMHO, it is better practice to declare the GUI element names as CONST at the start of your program along with other DIM statements etc. then they are globally available.
panky
Agreed.
