Local Time 02:01 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Comments access from MMBasic
panky
Posted: 09:36am 09 Aug 2019
Anyone know of any way to access comments that are embedded inside an MMBasic program from a running MMBasic program?
panky
Posted: 11:28am 09 Aug 2019
'This is a comment
do
j= peek(progmem,i)
if j=39 then s=1
if j=0 then
if s then
s=0
print ""
endif
j= peek(progmem,i+1) 'comment this line
if j=0 then exit do
endif
if s then print chr$(j);
i=i+1
loop
'This is another comment
print "Thats all folks"
Edited 2019-08-09 21:42 by matherp
CaptainBoing
Posted: 01:47pm 09 Aug 2019
without the faf, is it something you can put in DATA statements? so instead of
' this is a comment
you could have
DATA "this is a comment"
and then access it without the cryptic (albeit interesting) work that Peter just highlighted, with simple RESTORE and READ.
This also make those comments immune to CRUNCHing - which might be a problem if you have code that is expecting to have something useful in the comment.
Edited 2019-08-09 23:50 by CaptainBoing
panky
Posted: 10:53pm 10 Aug 2019
@matherp and captainboing,
Many thanks to both - exactly what I was looking for,
Panky.
