Local Time 01:57 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Strange video artifact on CMM
ceptimus
Posted: 10:41am 09 Aug 2019
Try this tiny program. It's an endless loop so you'll need Ctrl-C to exit:
Cls
You'll see the characters [2J[H strobing in the top corner of the screen. You can see them in every video mode, though the strobe rate alters depending on the mode.
If you prefer old-school then this version works just the same:
10 Cls:GoTo 10
I'm using V4.5C of Geoff's Maximite firmware - the latest version as far as I know.
Posted: 01:38pm 09 Aug 2019
This is just the VT100 Escape Codes for 'delete screen content' and for 'homing' the cursor to top left corner of the screen.
Must admit I have not seen this before until running your program! In normal use (of CLS) you will not see it.
WW
Poppy
Posted: 04:45pm 09 Aug 2019
To me this always comes up when the program does too fast screen clearing, apparently for its own capabilities, e.g. printing temperature or showing time.
Andre ... such a GURU?
ceptimus
Posted: 05:41pm 09 Aug 2019
The VT100 codes shouldn't be displayed by anything though (except when editing the source code). Terminals and monitor programs should react to them, not display them in readable form, and they shouldn't be getting anywhere near the VGA graphics pipeline.
cosmic frog
Posted: 06:21pm 17 Aug 2019
Using a comment after CLS causes the same error.
CLS 'comment
but,
CLS : 'comment
works ok.
I've known about this cls bug for a while but forgot to report it until I saw this thread.
Dave.
