Local Time 01:03 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects :
palcal
Posted: 03:22am 22 Aug 2019
My Laptop HDD went kaput so I bought a new SSD. Grogster did this a little while back.
My problem is I have mounted the drive and I have a windows installation disk but how do I format the drive. The installation starts and loads some files but then throws an error.
KeepIS
Posted: 04:32am 22 Aug 2019
Wondering what the error message said?
From memory the install disk will either format the disk or ask you how you want it initialised / formatted as far as partitions and or sizes.
Mike
NANO:Inverter V 8.4ksLinux AvrDude GUI script V4.1
palcal
Posted: 04:49am 22 Aug 2019
Yes I thought the installation disk would take care of it, I will check on the error again and see if I can research it on the web.
Posted: 04:57am 22 Aug 2019
Hi Paul,
I was able to access this thread by clicking on the DATE field..
Which windows version?
AFAIK they all will format the drive for you
Kind Regards,
palcal
Posted: 05:54am 22 Aug 2019
when I originally got the message (BSOD  0x0000007B ) I thought it must be a faulty drive so I bought a new SSD to replage the old HDD. But still get the message so now think it must be a different fault.
Posted: 06:21am 22 Aug 2019
Paul,
Are you sure your laptop HDD is faulty then?
Maybe your motherboard is kaputski?
Try the HDD (old) in a USB caddy and plug it into your PC and see if it works ok.
Mind you the HDD may have killed your laptop or vice-versa.
If you want I am always happy to try to recover the data off your drive for you.. PM if interested.
Kind Regards,
palcal
Posted: 08:50am 22 Aug 2019
Thanks Mick but all files were backed up.
