Local Time 01:04 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Color MaxiMite from micromite.org - no power button?
Decoy
Posted: 01:09pm 26 Aug 2019
Hi guys
I am thinking about buying a Color MaxiMite as a gift, completely assembled from micromite.org. However, it does not seem to have a on/off-switch?
It should be no problem installing a switch myself, but it seems weird to not have it present, right?
Thanks!
Chopperp
Posted: 01:54pm 26 Aug 2019
I think it is a standard feature for all CMM's.
There should be a jumper in the power supply part you can replace with a switch if required. Mine has.
You may be able to specify a switch in your order to save you doing it.
I think Geoff thought most users would leave it on continuously when he designed it.
I must admit, an On Off switch would be handy at times particularly if you have both a separate power supply as well as a USB connection. I removed the USB 5V connection on mine.
Edited 2019-08-26 23:55 by Chopperp
ChopperP
Poppy
Posted: 08:50pm 26 Aug 2019
Right above/behind the SD-Card-Socket there are two pins being bridged by a jumper, just install a switch instead.
On this pic you see it bridged by a piece of wire:
http://geoffg.net/Images/ColourMaximite/06.jpg
>>> "Power SW" <<<
For a Reset-Button you can switch "RES" from the Arduino-Pins to ground, probably a resistor inline to smooth it.
The Duinomite uses a 300 Ohm I think.
Andre ... such a GURU?
Posted: 07:52am 27 Aug 2019
@Decoy
Adding a Power Switch is an option that can easily be implemented.
I have sent you a PM . . . .
WW
