Forum Index : Microcontroller and PC projects : Armmite H7: 5.05.09, MOD file playback
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11879 |
Minor update that includes playback of .MOD files like the Colour Maximite. Armmite1.3.zip Armmite H7 Manual.pdf MOD files play on a continuous loop with the command PLAY MODFILE fname$ Playback is stopped with PLAY STOP Volume can be controlled with (0-100) PLAY VOLUME left%, right% The playback can be paused with PLAY PAUSE and resumed with PLAY RESUME The attached zip file includes a sample modfile. Playback is in 12-bit stereo at 44100 Hz Edited 2019-09-05 02:36 by matherp |
| PicFan Senior Member Joined: 18/03/2014 Location: AustriaPosts: 133 |
Hi Peter ! Thank you for your commitment. It should be possible to build an SDR radio with the H7. What is your opinion ? Greetings from Tyrol! Wolfgang |
Trivial fix for bug with 4.3" SSD1963 in 16 bit portrait mode Armmite1.3.zip This also includes an experimental capability for games programmers. You can now play a WAV file at the same time as playing a MOD file. The syntax is: PLAY EFFECT wavfilename$ [,interrupt] The WAV file must be stereo and recorded at 44100Hz otherwise you will get an error. The optional interrupt is triggered when the wav file completes. The MOD file continues playing continuously. Sorry - know nothing about SDR radio so can't comment. |
