Local Time 00:10 20 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ARMmite SSD1963_4_16,p causes system lock
astro1
Posted: 06:58am 15 Sep 2019
OPTION LCDPANEL SSD1963_4_16,p doesn't return from the command and power cycle has no response from AM. Need to re-flash.
SSD1963_4_16,L and SSD1963_4,P works fine. Both 16 bit L & P work OK on 7"
Running 5.05.09, while testing out MOD files playback. :')
Frank
Posted: 09:05am 15 Sep 2019
  Quote  OPTION LCDPANEL SSD1963_4_16,p doesn't return from the command and power cycle has no response from AM. Need to re-flash.
You can always reset options by holding down the USER button while pressing RESET
Bug fix included in main 5.05.09 thread
Edited 2019-09-15 21:15 by matherp
