Local Time 23:21 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : F4 Display Box Text Size
Chopperp
Posted: 12:04pm 16 Sep 2019
Playing with GUI stuff for the first time on a 7" display on an F4.
I have this code for a display box & text using CTRLVAL.
However, I cannot get the Font size to change. Stays at No 2 (Small).
FONT seems to work on a Caption box OK.
What am I doing wrong?
 gui displaybox #1, 10, 415, 330, 50, grn, cBGnd
 font 5,1: CTRLVAL(1) = "BACKLIGHT = " + str$(B_Light)
Also, how do you use DAY$? I can't get any sense out of it with: PRINT DAY$
Brian
ChopperP
Posted: 12:55pm 16 Sep 2019
DAY$(date$) Returns the day of the week for a given date as a string “Monday”, “Tuesday” etc. The format for date$ is “dd-mm-yyyy”. Use NOW to get the day for the current date, e.g. ? DAY$(NOW)
Don't know much about the GUI commands but I suspect the font size is associated with the control so needs to be set before the GUI command
Edited 2019-09-16 22:57 by matherp
Chopperp
Posted: 01:14pm 16 Sep 2019
Thanks Peter.
The DAY$ fn makes sense now.
I'll try putting the Font cmd before the GUI cmd & see what happens.
I don't know much about them either.
Brian.
Edited 2019-09-16 23:18 by Chopperp
ChopperP
Chopperp
Posted: 08:57am 17 Sep 2019
OK
This works with the FONT command before the GUI Displaybox command. (The FONT statement after the GUI Displaybox command didn't).
 FONT 4
 CTRLVAL(1) = "BACKLIGHT = " + str$(B_Light) + "%"
The other examples I was following had the FONT statement immediately before the text as I originally posted.
Got DAY$ tested OK thanks Peter
Brian
ChopperP
