Local Time 19:33 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Audible Alarm For MM170
Andrew_G
Posted: 02:28am 10 Nov 2019
My BBQ Probe (see here) is progressing well with the probe temperature and timers being shown on a MM170 LCD BackPack. I flash the screen red as the probe approaches the set temperature etc.
What I am lacking is an audible alarm.
Do any of you have any tried "solutions"? (this will have other applications too). (And yes I know the MM+ can do better).
Preferably loud enough and low enough frequency for my aged hearing (and even with adjustable frequency and volume? - either in the circuit or via setup on the LCD).
I have tried fixed frequency buzzers (with a trimpot to adjust volume - too high a frequency for my ears) and allegedly PWM controllable ones for Arduino (much too quiet).
Many thanks,
Andrew
BrianP
Posted: 05:26am 10 Nov 2019
  Andrew_G said  Hi,
Many thanks,
Andrew
You need to cycle through a range of frequency - like police / ambo sirens. You also need an amp to boost the PWM - there are heaps of very small single board / chip possibilities out there, 5-12v powered. You could then use this to drive a piezo sounder thingy - some of these are really loud (you need a passive one, not one of the fixed frequency ones).
Also there are small single board police siren emulators - just feed them the volts & away they go. Jaycar or Altronics should have them. Although letting the micro do the PWM would let you choose the best range that suits.
B
Andrew_G
Posted: 03:39am 11 Nov 2019
Brian,
Many thanks! I paid my local Jaycar shop a visit and settled on.
It is a magic little amplifier that does the trick for me.
I also bought a number of passive buzzers to play with and this speaker .
Now I can now use the PWM command to get notes etc.
All buzzers/speaker are loud enough for an alarm. I might add a trim-pot for volume control.
I'd make the following comments about the amplifier:
- it is stereo (I only need one channel)
- it is really small and inexpensive ~Au$5
- its pinouts are spaced for cable connections, not pins/headers, but I was able to cheat and force the ones I needed to standard headers for breadboard etc.
- it has a pin "SW" for "Switch" which, when grounded, turns the amplifier off - I'll use that with touch control for "Mute".
Cheers,
Andrew
Andrew_G
Posted: 05:04am 11 Nov 2019
I've spent an hour or so playing with alarm sounds on my MM170.
(The dog doesn't like the high pitched ones.)
Here is what I have so far (80:20 rule).
 For I = 1 to 50   'Just a loop so you get the idea
   TimerOld = Timer
   PWM 2, 300, 10  'PWM 2 (is Pin # 26), Frequency, DutyCycle
   Do:Loop While Timer < TimerOld + 500  '500 is the duration of the "note" in mS
   TimerOld = Timer
   PWM 2, 600, 10
 Next I
 PWM 2, STOP     'Otherwise it keeps playing the last "note"
Do any of you have any snippets to suggest?
Is there a "Library" of MM sounds or even ditties?
(I'm really looking for a bit of friendly competition here . . .)
Cheers,
Andrew
Edited 2019-11-11 15:07 by Andrew_G
twofingers
Posted: 04:38pm 11 Nov 2019
  Andrew_G said  Do any of you have any snippets to suggest?
I'm using "bird" and "siren" for a small piezo buzzer:
Option explicit
Dim T1 'temperature from a DS18B20
Dim j  'loop counter
const threshold=22
 TEMPR START 3, 3
 T1= TEMPR(3)
 Print T1
 If T1 <threshold Then
    For j = 1 To 5
      bird 'or siren
    Next j
    PWM 2, STOP
    Print "L"
    Pause 2000
 EndIf
Sub bird
Local integer f1,f2
    For f1 = 440 To 3000 Step 200
      PWM 2,f1,50
      Pause 10
    Next f1
    For f2 = f1 To 440 Step -200
      PWM 2,f2,50
      Pause 10
    Next f2
End Sub
Sub siren
Local integer f1,f2
      PWM 2,f1,50
      Pause 10
    Next f1
      PWM 2,f2,50
      Pause 10
    Next f2
End Sub
The lone and ...
Andrew_G
Posted: 10:05pm 11 Nov 2019
Thanks Twofingers,
Very good - I will pinch them if I may??
OK Shedders - any other snippets?
Your code also helped me understand:
- PAUSE actually does pause the execution (I put "PRINT TIMER" before and after and then in a second test removed the Pause - sounded very different). From my reading of the manual I expected the "tone" to not stop but to continue until the next "PWM" command (eg as occurs with a ^C).
Hence my clumsy workaround of " Do:Loop While Timer < TimerOld + 500". I'll change to PAUSE from now on.
- I don't need a trimpot for adjusting volume - just alter the dutycycle parameter!
- TEMPR START to set the precision of the DS18B20 reading (I have, without thinking, been using the default - OK for some applications but not all).
Thanks again,
Andrew
Edited 2019-11-12 11:58 by Andrew_G
twofingers
Posted: 11:36am 12 Nov 2019
Hi Andrew,
  Quote  Very good - I will pinch them if I may??
sure, it is posted for that.
I hope, you will get more code snippets.
Michael
The lone and ...
Turbo46
Posted: 12:13am 13 Nov 2019
You might like to have a look at this post for some sounds.
Bill
Edit: Another approach could be to write a routine that imitates the Maximite SOUND or TONE commands and pinch some sounds from Maximite games?
Edited 2019-11-13 10:34 by Turbo46
