Local Time 19:33 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Backpack144
Phil23
Posted: 04:12am 15 Nov 2019
For Some Reason I managed to post this in the Guest Forum.
Hi All,
I have a Backpack144 from WW that's been sitting here on the shelf for a while & looking at getting it up & running.
Don't seem to be finding relevant treads regards the board & a few I'm finding are giving 404 errors.
Anyone point me in the right direction?
I can power it up on USB & get a prompt but don't think the 7" display is backlighting.
It's alive & I get this from the console.
print mm.ver
5.0321
> option list
OPTION CPU 252
OPTION COLOURCODE ON
OPTION DISPLAY 24, 53
OPTION LCDPANEL VGAOPTION KEYBOARD US
OPTION SDCARD 93, 94
OPTION LCDPANEL CONSOLE
OPTION HEARTBEAT ON
Phil.
Edit:-
It's a Red PCB & Version 1.1 & the above are probably WW's shipped settings.
Edited 2019-11-15 14:13 by Phil23
panky
Posted: 04:29am 15 Nov 2019
Phil,
For the 7" display, you need the following options set
OPTION LCDPANEL SSD1963_7A_16,RL,,142
... now do a GUI TEST LCDPANEL  and there should be circles galore.
Now for touch
OPTION TOUCH 118,121,103
... then GUI CALIBRATE
You might also like to set up the RTC
OPTION RTC 15,16
The MMX Manual has pin descriptions.  If you need a schematic and/or a diagram of the GPIO pinout, PM me with an email and I will send to you.
Doug.
mikeb
Posted: 04:46am 15 Nov 2019
If you have set the links on the back of the display to use PWM then -
At the Command Prompt enter BACKLIGHT nn (nn being a decimal value between
0 and 100). This command must be re issued each time you reset the board by
any means.
Include this command at least at the start of your program.
This sets the backlight PWM signal.
Note that a value over 50 - 60 does nothing more than increase the current consumption with little difference in display brightness.
Regards, Mike B.
Posted: 08:05am 15 Nov 2019
Quick reminder, you can Search using google with things like
site:www.thebackshed.com Backpack144
To just get things from a specified site.
You can use a longer URL and more of a search e.g.
site:www.thebackshed.com/forum something wanted
(you might also include a forum member's name if you're sure who posted)
Phil23
Posted: 10:45pm 16 Nov 2019
  JohnS said  Quick reminder, you can Search using google with things like
Yes have employed most of those sorts of queries in various forms.
Catch is I'm finding a few that go to 404's.
I recall there was quite a lot of discussion back at build time, that's the main bit I'm struggling to get hits on.
Have the manual I downloaded at the time, but it doesn't specifically cover this board & it's revisions.
