Local Time 18:36 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CP/M on nano
zeitfest
Posted: 11:17am 02 Dec 2019
CP/M and various languages games etc running (slowly) on an arduino nano...
pretty amazing, even if just for the exercise
CP/M
Posted: 09:13pm 03 Dec 2019
i wonder what the performance is like?
this does give me an interesting idea, a 28-pin MX170 running a Z80 emulator written in C and CP/M on top of this. if one allows 8k of RAM for the emulator and C runtime, that leaves 56k of RAM for CP/M. the other 8k of the Z-80 address space can contain the BIOS.
onboard peripherals would be:
- the two hardware serial ports of the MX170 (one as the console),
- I2C could be used for RTC,
- SPI for SD card/file system,
- other spare pins as a general purpose 8-bit I/O port plus strobe/ack.
how cool would that be? a complete CP/M computer running on a single 28-pin DIP?
peter, geoff: would a Z80 emulator and the other odds-and-ends required fit into the 256k flash of an MX170? would there be enough flash left over to also hold a 56k ram image - thereby allowing just the single MX170 chip alone to boot to the CP/M command prompt?
rob   :-)
Posted: 02:04am 04 Dec 2019
Many years ago I tried implementing a Z80 emulator on the MX695 used in the Maximite.  It was rather clunky but it worked and turned the Maximite into a CP/M machine.  The problem was that I could not guarantee that CP/M and the other programs (like Microsoft BASIC) were in the public domain and for a magazine article that was essential.  Emulating the various display controllers was also an issue.
I cannot remember how much flash it used but I am sure the emulator would fit into 256K.
I grew up on CP/M but these days it seems incredibly limited and I would wonder why anyone would want to play with it (despite the nostalgia factor).  It is like wearing a hair shirt because you were forced to wear one as a child.
Posted: 05:23am 04 Dec 2019
it sits alongside the moderately usable Z80-MBC2 that several forum members have previously built:
https://hackaday.io/project/159973-z80-mbc2-4ics-homemade-z80-computer
and this much earlier linux on an atmega1284:
http://dmitry.gr/index.php?r=05.Projects&proj=07.+Linux+on+8bit
that is summed up thus: "uARM is certainly no speed demon. It takes about 2 hours to boot to bash prompt ("init=/bin/bash" kernel command line). Then 4 more hours to boot up the entire Ubuntu ("exec init" and then login). Starting X takes a lot longer. The effective emulated CPU speed is about 6.5KHz"
both the above are technical achievements, although of at best little practical use!     cool, like owning a jet fighter plane. but not cool like owning a fridge. of course, the MX170 running mmbasic is cool in both ways
rob   :-)
Frank N. Furter
Posted: 08:31am 04 Dec 2019
the Z80-MBC2 is really nice! It works very fine with Geoff's "ASCII Video Terminal" but very much better with a Pi Zero as graphic card (NOT a Pi Zero W!!!)
I also have CP/M running on a Duinomite. In the beginning I had big problems with the Micro-SD card.
Now I found a 16MB Micro SD card that works very well! Microsoft BASIC and Turbo Pascal 3.0 also work on the board.
Frank
Posted: 11:43am 04 Dec 2019
interesting Frank, the Z80 simulator appears to have been written by a fellow called Ken Segler, with a complete mplab-x pic32 project for it located here:
https://github.com/TheCodeman/z80pack-1.17-ksd-pic32
looks like there has been no activity for years, but i wonder if someone could just rip out the surplus bits (vga and keyboard support) and recompile for the MX170? as i said before, it is of almost no practical use, but nonetheless rather cool. imagine being able to hand someone a 28-pin DIP package and tell them it is a complete CP/M computer!
geoff: the licensing status of CP/M does indeed seem a little unclear - while widely accepted as now being 'open source', the letter from Lineo isn't quite so cut-and-dried:
"Let this email represent a right to use, distribute, modify, enhance and otherwise make available in a nonexclusive manner the CP/M technology as part of the "Unofficial CP/M Web Site" with its maintainers, developers and community"
rob   :-)
Frank N. Furter
Posted: 06:02pm 04 Dec 2019
@Rob:
Ken was in 2011 with the Z80 emulation in our forum.
The SD-Card Library would have to be replaced by that of this TRS-80  project. As I said, I had big problems with the SD card and Z80!
This TRS-80 emulation runs very nicely on a Duinomite.
It would be very nice to have a CP/M system on an MX170!
Does anyone know a comparable emulation of a PET2001? - that would be my dream!!!
Frank
jman
Posted: 07:14pm 05 Dec 2019
  Frank N. Furter said  @Rob:
Frank
Ditto :)
Posted: 11:54pm 05 Dec 2019
  Frank N. Furter said  Does anyone know a comparable emulation of a PET2001? - that would be my dream!!!
that would be a far more daunting task - to emulate a full system like a PET would require generating a video output, and accurately emulating all the other hardware that sits around the CPU. a bit beyond the abilities of an MX170 methinks.
with CP/M, basically all one needs (aside from the Z80 emulator) is a serial port for the console and to trap disk I/O calls to the BIOS.
having said this, there are a few projects involving static recompilation out there. one such example provides for the core of microsoft 8-bit basic on a number of different platforms. see:
https://github.com/mist64/cbmbasic
essentially, you take an 8k ROM image from your favourite 1980's home computer, and translate the machine code (using an automated process) into calls to C equivalents of the machine instructions. you then go through the C code by hand and patch anything that hits hardware outside of the CPU. it is rather cool from a technical perspective, but not as useful as mmbasic in the real-world.
rob   :-)
Frank N. Furter
Posted: 08:13am 06 Dec 2019
I found this code on the net. In the near future I want to run this code on an Odroid-Go with a buddy who is a software developer...
You are right! In the real world MMBASIC makes much more sense!
@jman: Have you tried the TRS-80 emulation on a Duinomite? It takes some getting used to, but it's a lot of fun!
Frank
cosmic frog
Posted: 11:07am 06 Dec 2019
I tried the TRS-80 (MaximiteTRS80.hex) file on my home built Maximite but all I get is a black screen. Just can't see what I'm doing wrong.
When I reflash back with the Maximite (ColourMM_MMBasic_V4.5C.hex) everything works ok.
Dave.
Frank N. Furter
Posted: 11:39am 06 Dec 2019
Hi Dave,
I have not tried the "MaximiteTRS80.hex" only the "OlimexDuinomiteMiniTRS80.hex" on a Duinomite Mega.
Is your home built Maximite a Colour Maximite?
I think there were some small differences between the UBW32 Colour Maximite and the "normal" Colour Maximite... - You should check the schematics again.
Have you copied ALL files to a FAT formatted SD card? There are some files that the emulator needs! - have you ever tried another card? I have only used a 2GB SD card so far...
Frank
jman
Posted: 06:16pm 06 Dec 2019
  cosmic frog said  I tried the TRS-80 (MaximiteTRS80.hex) file on my home built Maximite but all I get is a black screen. Just can't see what I'm doing wrong.
Dave.
@ Frank Yes but on a UBW32 using Mick's PCB.
Hi
The issue here is the bootloader. Use the attached bootloader (The UBW32 version)
Flash with a PIC3. Once done MMBasic and the TRS80 can be used via the normal USB upload method.
Jman
UBW32_HIDBoot_MX795.zip
cosmic frog
Posted: 07:21pm 06 Dec 2019
Hi Frank. Yes it's a colour Maximite built around the mx695 chip but I've also got a UBW32 spare so I will try that this weekend.
@jman. I will also try your file.
Thanks. Dave.
cosmic frog
Posted: 10:30pm 09 Dec 2019
I finally set up my UBW32 and got the TRS80 to boot up, but it just sits on a screen that says MEM SIZE_ and the keyboard doesn't seem to work.
Any ideas?
I've checked all my wiring and all seems ok.
Any help would be appreciated.
Thanks.
Dave.
Frank N. Furter
Posted: 07:56am 10 Dec 2019
Hi Dave,
the one with MEM SIZE already looks quite good! Normally you just have to press RETURN now...
Have you tried another PS/2 keyboard?
Frank
cosmic frog
Posted: 08:56am 10 Dec 2019
  Frank N. Furter said  Hi Dave,
Frank
I haven't tried one yet, that was going to be my next test. I also thought about trying another mem card, the one I'm using now is an old 1gig.
I'll let you know how I get on.
Many thanks.
Dave.
cosmic frog
Posted: 12:05pm 10 Dec 2019
Ok, I got it to work. Turns out it was a bad wire on the keyboard power connector and now it runs great!
Not sure why it wouldn't work on the MX695 chip, maybe there are some differences other than the CAN BUS.
Thanks again for everyone's help.
Dave.
Frank N. Furter
Posted: 12:13pm 10 Dec 2019
Frank
