Local Time 17:17 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Radio Buttons & Save Image
Chopperp
Posted: 12:55am 22 Jan 2020
Hi
On a F4 with a SSD1963 7" screen, I have 2 Radio Buttons in a frame & another separate one for a manual Save Image Routine.
All work OK except when I do a Save image, the lit "LED" center on one of the pair of Radio Buttons goes out & I have to restore it after the image save (~ 2 secs).
The LED center on the Image Save Button Stays on until the process has been completed.
The resultant *.BMP images mostly show the Framed buttons as OFF & the Image Save button On, but occasionally, one of the framed buttons will be On & the Image Save center, Off.
Just wondering if the Save Image routine is supposed to capture the status of the Radio Buttons, or could I be doing something wrong?
Edit
OR is the Save Image button just turning off the framed buttons when pressed.
Edit 2
Running the Save Image routine from the command line has the framed buttons showing correctly.
Brian
Edited 2020-01-22 11:18 by Chopperp
ChopperP
Chopperp
Posted: 09:17am 25 Jan 2020
OK......
Back to the Radio buttons. Found that putting a frame around the single button solved my dilemma.
Brian
ChopperP
