Forum Index : Microcontroller and PC projects : TLP250H(F) - a very useful I/F chip
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11879 |
My cut and paste of the spec for the chip seems to have contained something that the board rejected and killed the post. Can't remember what I wrote now Basically this chip is an opto-isolator with a halfbridge output capable of 2.5A source or sink. Perfect for isolating the uP from any higher voltage peripherals you want to drive. Motors, LEDs etc. |
Tsk, Tsk. This is why I always compose under Simplenote. I can start the post on my PC and finish later on my phone/tablet and the composition doesn't mysteriously vanish. But this is a find and perfect timing...many thanks, Pete |
Thanks for the Info Peter, Looks interesting, I have bought some to have a play with. I don't think your original post is totally lost as the Number of REPLIES is out by 1. Kind Regards Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Anyone grab any of these yet? Think I might just order some. |
Hi Tinnie, Mine have not arrived yet. Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Hi Mick, I totally missed the "I have bought some to have a play with" Had a look at the data sheet and picked up on the fact that they require bypass caps. Regards, Craig |
