Local Time 16:16 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS1307 RTC ... Error.
kermess
Posted: 12:13pm 25 Feb 2020
I am assembling and testing the DS1307 RTC and the system gives me an error.
[10] RTC settime 2020,2,25,12,3,0
Error: RTC not responding
I've tried it with several MX170 and several DS1307 always gives me the same error.
I am working with version 5.05.02
??? .... Can you think of something that isn't doing well .... ???
Saludos.
David Perez
palcal
Posted: 01:41am 26 Feb 2020
I always use DS3231 and they work OK. I assume you are using a module, just check you have 3.3v to the module and make sure the Data and Clock lines are going to the correct pins. Other than that try another RTC.
zeitfest
Posted: 11:54am 26 Feb 2020
(if it has one) Is the battery ok  ?
PeterB
Posted: 10:56pm 26 Feb 2020
G'Day David
I don't think I have used a RTC on MMBASIC but never-the-less.
There is an OPTION RTC command, have you done that?
Other than that, check your wiring and check for activity with a CRO/DSO if you have one.
Good luck
Peter
Posted: 12:55am 27 Feb 2020
Hi.
Make sure your RTC module has the 4k7 pullup resistors on SDA and SCK.
As with palcal above, I also really only ever use the 3231 or 3232 RTC modules, but as far as I know, the 1307's are also supported.
Standard manual, page 27, talks about RTC's, and the 1307 IS supported along with several other common ones, so it should work just fine.
It WON'T respond, if you don't have those 4k7 pull-ups on the I2C bus lines though, so please do check that they are present and in the correct place.  Not all modules include them.  Some do, some don't, and those two little resistors DO matter.
