Local Time 13:01 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Display not working on MMX 100pin
athlon1900
Posted: 12:22pm 20 Mar 2020
Hello to all !
My problem is that all my displays with ILI9341 controller are not working on the MMX-100pin.
I've tested the displays on a MX170-28pin without any error and they are working perfect.
My pin-configuration on MMX 100-pin is ( SPI-Channel 1 ) :
pin76 (spi-clk) ---> display (sck)
pin77 (spi-in) ---> display sdo (miso)
pin78 (spi-out) ---> display sdi (mosi)
pin73 (my D/C) ---> display D/C
pin71 (my RESET) ---> display RESET
pin68 (my CS) ---> display CS
I've init the display with " option lcdpanel ili9341 , 73 , 71 , 68 " , but nothing happens.
GUI TEST LCDPANEL does nothing.
Pins are tested in dout-mode (setpin(xx),dout). There is no Problem , Pins working perfect.
What i'm doing wrong ?
Geetings from Austria ,
athlon1900
EDIT: of course i init the display with " option lcdpanel ili9341 , LANDSCAPE , 73 , 71 , 68 "
Edited 2020-03-20 22:47 by athlon1900
Posted: 01:04pm 20 Mar 2020
  Quote  My pin-configuration on MMX 100-pin is ( SPI-Channel 1 ) :
Check the manual; you should be using SPI2
athlon1900
Posted: 01:24pm 20 Mar 2020
Thanks Peter    , i've found it in the MM+ manual.
The descriptions are a little misleading , a part here , a part there.
I'll try it and post the status.
athlon1900
Posted: 07:05am 21 Mar 2020
Hi Peter !
I've tested it with SPI2. No chance.
On my Board Pin10 ( spi2-clk ) is not working. Chip must be faulty. There is no short on the board.
Is it possible to use another spi-channel (like the sdcard) ?
Posted: 08:52am 22 Mar 2020
  Quote  I've found it in the MM+ manual
Are you using MMX or MM+?
Pins for 100-pin MMX SPI2 are, as per the MMX manual:
72 SPI2-IN (MISO)
66 SPI2-OUT (MOSI)
10 SPI2-CLK
Can you use an SDcard? Can you use touch on a SSD1963? Both of these use the same channel.
Try:
Connect pin 66 to pin 72
OPTION RESET
SPI2 OPEN 1000000,3,8
DO:?SPI2(&H55):LOOP
And see what you get and if there is activity on pin 10
Edited 2020-03-22 18:54 by matherp
athlon1900
Posted: 11:39pm 23 Mar 2020
Hi Peter , thanks for your answer.
72 SPI2-IN (MISO)
66 SPI2-OUT (MOSI)
10 SPI2-CLK
I only found your tip with spi2 in the MM+ manual.
Im working on MMX 100-Pin. You are right , these are the pins I want to work with.
The SDcard do the work only on SPI1 or SPI3. Not on SPI2
I only have 2,8" displays with touch and ILI9341 controller. For me it's enough
  matherp said
Try:
OPTION RESET
DO:?SPI2(&H55):LOOP
Ok i'll try your code , but I'm pretty sure that pin10 is dead.
My test was a simple SETPIN(pin),DOUT test with a blink-pgm and leds on these 3 pins.
pin 66 = OK
pin 72 = OK
pin 10 = not OK , no act
As i wrote : on the chip-pins there are no shorts. No short to pin 9 or pin 11.
I2C-channel 1 ( pin11 and pin12 ) tested and works with a 20x4 Display.
athlon1900
Posted: 01:44pm 03 Apr 2020
Hi Peter ,
i have tested your code.
All what i get is only 255 and no act on pin10.
That means , that pin10 is definitivly dead on my MMX 100pin and SPI2-channel is not to use.
SPI1 and SPI3 are working with the SDCARD.
My hope is , that you can make the display and touch SPI-channel also selectable like the SDCARD in the next MMBASIC-version , that would be great
