Local Time 15:11 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PWS Weather.com
MikeO
Posted: 11:54am 29 Mar 2020
WPSweather.com has a new web site where home weather stations can post their weather data.
Here is the Annex code portion to achieve this.  See my web site
'now send YARRAGONAU via HTTP @ PWSweather.com
 d$="20"+DATE$(2)
 d$=replace$(d$,"/","-")
 pws1$="dateutc="+d$+"%20"+time$+"&ID=YARRAGONAU&PASSWORD="your_password=updateraw"
 pws2$=pws1$+"&tempf="+otf$+"&humidity="+oh$+"&dewptf="+dpf$
 pws2$=pws2$+"&windspeedmph="+wsm$+"&windgustmph="+wgm$+"&winddir="+wd$+"&baromin="+pri$
 pws2$=pws2$+"&dailyrainin="+rai$
 pws2$="www.pwsweather.com/pwsupdate/pwsupdate.php?"+pws2$
 'wlog pws2$
    WGETASYNC(pws2$, 80)
    pause 300
I have also written a REST API to upload live data (eg from annex) to a website page , an example is the Garden Solar page on my website
<?php
REST Get request API interface to
update a json file
updatefile.php
usage: url/updatefile-xx.php?key="your_api_key"&file="filename"&json="json string"
codenquilts.com.au
$rpath="data/";
//$apikey="your_api_key";
//grab the values sent in the GET request, API Key Filename and JSON string
$key=$_GET['key'];
$file=$_GET['file'];
$json=$_GET['json'];
//echo ("$key");
//example json string
//json={"Peter":35,"Ben":37,"Joe":43}
//echo ("$json");
//echo ("$rpath" .  "$file" . ".json");
if ($apikey == $key){
$result=file_put_contents($rpath .  $file . ".json", $json);
//echo ($result);
if ($result >= 1){
echo ("ok");
} else {
//e2: failed db write
echo ("e2");}
} else {
//e1: failed api key
echo ("e1");
//close the connection
mysqli_close($link);
Mike
Hope you are all OK, Stay Safe, Stay Home if you can.
Codenquilts
