Local Time 15:10 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : If statement syntax
Chrisk
Posted: 12:56am 30 Mar 2020
Hi Guys
Just a question on correct syntax.
If I have the following 'if' statement
if LTA > Mxt then
Mxt = LTA
else
endif
Can the 'else' be omitted as it does nothing or should it be retained?
If it should remain then why?
Chrisk
jman
Posted: 01:05am 30 Mar 2020
Hi
Yes the else can be removed.
you could also use
if LTA > Mxt then Mxt = LTA
and omit the endif
Jman
Chrisk
Posted: 06:33am 31 Mar 2020
Great
Thanks Jman
Stay healthy
Chrisk
