Local Time 13:01 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMbasic Interpreter bug? [with OPTION DEFAULT]
MustardMan
Posted: 09:56pm 21 Apr 2020
When using OPTION DEFAULT NONE to enforce good programming habits (everything must be properly defined), I get an error with EXIT FOR. I have attached the relevant code snippet below:
OPTION EXPLICIT        ' All varibles must be explicitly defined before use
OPTION DEFAULT NONE    ' And all variables must have their type explicitly defined too
CONST params = 16      ' It seems constants can't have their type specified (??)
DIM INTEGER n          ' General use
       FOR n = params TO 1 STEP -1          ' Check backwards: no touch results in n=0
         IF CheckPress(n) THEN EXIT FOR     ' Exit FOR loop early if a touch is detected
       NEXT n                               ' n = index (0 = no touch, or touch in wrong area)
The "button" check is done backwards resulting in a non-button area touch being zero. This is easier to deal with (in a program) than checking for '= params+1' or '> params'.
The error thrown is:
[119] If CheckPress(n) Then Exit For
Error: Variable type not specified
If I comment out the OPTION DEFAULT line, it works fine.
Interpreter version output with "? MM.VER" is 5.0502, and it is running on a MicroMite Explore 100.
As a side note, I was not able to define the type of a constant (tried AS INTEGER, INTEGER, before, after, used DIM, no luck). Can I not define the type of a constant?
Cheers,
Posted: 10:54pm 21 Apr 2020
I could not get this to fail (Ver 5.05.02).  Perhaps there is something going wrong in the function CheckPress() that is causing MMBasic to report an error in the wrong place.
This is the test code that I used:
      NEXT n
  Function CheckPress(a as integer) as integer
    CheckPress = 0
  End Function
On your second point.  Yes, you are supposed to be able to specify the type of a constant.  But doing that caused an error in your test code.  I will add this to the bug list for the next version.
Turbo46
Posted: 11:20pm 21 Apr 2020
Geoff, I quickly tried MustardMan's program and it failed because CheckPress was not specified.
It says several times in the manual that a CONST defaults to the implied data type:
  Quote  When a constant number is used it will be assumed that it is an integer if a decimal point or exponent is not used. For example, 1234 will be interpreted as an integer and 1234.0 will be interpreted as a floating point number. String constants are always surrounded by double quote marks (eg, "text string").
  Quote  The identifier can have a type suffix (!, %, or $) but it is not required.
So for that reason I thought it is not necessary to specify the type of a constant?
Bill
MustardMan
Posted: 02:49am 22 Apr 2020
@Turbo46
My apologies, I will post more of the program this-evening when I get home. I suppose thinking there might be a bug does call for a bit more than a tiny snippet of code! As Geoffg has pointed out, it may well be the definition of "CheckPress()" that is my problem.
I did read in the manual that constants were typed by the value that they were given, which is fine, and really easy. Coming from a C background where things are much 'tighter', I did not think of trying symbols when specifying a constant. I instinctively thought to "word" it (eg: FLOAT) rather than "symbolise" it (eg: $) to make it something in particular.
Cheers,
Posted: 03:14am 22 Apr 2020
I have since checked the manual and it does indeed support the current behaviour.  However, to me it would be more consistent if CONST supported full typing like DIM.  From memory that part of the code was complex and maybe that is why full typing did did not make it in.
Anyway, I will investigate.
Turbo46
Posted: 03:17am 22 Apr 2020
I'm sorry too MustardMan. I assumed that your snippet was expected to show the problem as was. Geoff knew better on both points of course. I was writing my post when his popped up. I probably should have deleted the contents and shut up.
Bill
PS. It happened again!
MustardMan
Posted: 10:38am 22 Apr 2020
@Turbo46 and @Geoffg
Well, I do feel stupid - Geoff was spot on with his diagnosis, it was the definition of 'CheckPress()'.
The original:
FUNCTION CheckPress (n AS INTEGER)
LOCAL INTEGER x = TOUCH(x)
LOCAL INTEGER y = TOUCH(y)
blah blah
And the way it should be, and working...
FUNCTION CheckPress (n AS INTEGER) AS INTEGER
blah blah
With regard to constants: it is not an issue, I just wondered if it was supposed to support word definitions or not, and 'not' it is!
Cheers, and many thanks!!!
