Forum Index : Microcontroller and PC projects : Piclog controller
| nzdrunkricknz Newbie Joined: 08/08/2013 Location: New ZealandPosts: 4 |
Hi With the lockdown here in NZ I thought I would have a go at building the Piclogger 2.0 that is on the website. Is it still a good build, is there samething better or is there an update to it? Being that it is 15 or so years old now. I have a picaxe14m all ready I did want to add multiple volts ,amps ,watts, for different power sources. But to start just get it running on my wind turbine. And logging to a server. Rick |
| Gizmo Admin Group Joined: 05/06/2004 Location: AustraliaPosts: 5194 |
That's a really old project now, but it should still work. A lot of my early projects like the PicLog were mostly put together as open source projects, so people could learn how they worked and modify them for their own needs. The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Thank you for your replay. Is there a better option you know of for a basic volts amps watts viewer/data logger that can be sent to a PC? |
